Plex Over VPN on Qnap
Good Morning All,
Anyone has Plex running over a VPN under his QNAP ?. I simply want Plex to use my Real Gateway instead of the VPN gateway. I publish my Real IP VIA custom URL under network in Plex, but it must use my standard Gateway instead of the Gateway of the VPN but I have other app on my QNAP that must used the VPN Gateway to be able to access out of country content !.
I’m not a Linux guru, but I want to add a route for port 32400 to my default network Gateway, how can I do taht on my Qnap ?
Best Regards,
Sylvain
I would also like to do this! Let me know if you have any success.
Hi !
Working perfectly for several months, not using the VPN, just add custom server access URLS in the network setup of your Plex media server !
HTH,
Sylvain
Hey hoW does thé above solution work? Would it be possible to give a description.
