Plex PC app not be able to work with multi monitor setup
Server Version#: 1.32.1.6999
Player Version#: 1.68.2.3746-7601b337
Hi everyone,
I’m running the Plex windows app because the web application has multible issues with interrupting, fast forward and converting issues even all converting features are disabled.
But now the windows app has also a major issue preventing it from normal use. It can’t work with multi monitors which ends up in resize failures. These issues lead to not be able to start or stop the playback, and above all will persist if the app is closed and restarted again.
I have at the moment six monitors which all run on different resolutions because it’s necessary for my work. Is there a possibility to research and fix this issue? I would open a support ticket, but there is no support???
Regards CrystalSurface
I also saw this problem with my two monitor setup. Especially with a different size and resolution monitors.
