Plex Preferred Network Interface not working properly
Server Version#: 1.16.3.1433
I’ve been trying to get Plex working with my dual WAN setup for a week now but haven’t been able to figure it out.
Network setup:
WAN #1 (1000mbps down/20 mbps up) - I want to use this as my primary internet connection for all my devices. This WAN is hooked up to an ASUS router.
WAN #2 (200mbps down/200mbps up) - I want to route all Plex traffic through here since it has significantly more upload. This WAN is provided by a modem/router combo from the second ISP.
My Plex server is hosted on a Windows 10 machine with dual NICs - NIC1 is connected to the WAN #1 router, NIC2 is connected to the WAN #2 router. I’ve set the IPV4 metric on NIC1 lower than NIC2 and as expected, all Windows applications will connect to the internet through WAN #1. I then set Plex’s preferred network interface to NIC2. Despite this, when I load up the Remote Access tab, it will show my WAN#1 IP address as the public IP and then tell me the server is not accessible from outside the network. If I disable NIC1, it will immediately show WAN #2 IP address as the public IP and is fully accessible from outside the network. If I reenable NIC1, it will show WAN #1 IP address again and “not accessible”
What am I missing? It seems like the Preferred Network Interface setting isn’t actually binding Plex to NIC2 - it just binds to whatever NIC has the lowest metric.
I’ve had the same issue (on QNAP NAS). Preferred network under network settings points to qvs1 but the remote access piece shows the IP address for qvs0.
This seems to be resolved in the latest build 1.16.5.1488
That’s good news. I’ll give it a try tonight
Seems like the latest build ( 1.16.5.1554) breaks this again. :anguished:
