Can someone tell me how i can be certain i am using plex premium music? I have 1.18.2.2058 installed
thanks
thanks
There is no longer a “premium” vs. “basic” schema.
thanks for your message.
what i want to be sure i’m using is this
i dont see an option to upgrade to plex music but i would like to be certain if it is being upgraded or not?
thanks
If the ‘Upgrade to Plex Music’ is not present on the Manage Library menu, the library was either a Premium library to begin with, or it has already been upgraded. In either case, as noted in the article, there are new options in the Advanced tab of the Edit Library dialog. If you see the new features, and you’ve Refreshed Metadata on all your Artists, you’re upgraded. The “What to Do After You Upgrade” section describes the new features, and what you need to do.
I’m looking at trying to use ‘moods’. It seems nothing I do work. I’m confused now as to why they’ve merged the feature with no communication… Is there any reason selecting moods has no options then or what…?
Saying that, I have just found this: https://support.plex.tv/articles/upgrade-music-libraries-new-metadata-system/?_ga=2.268287886.185883216.1576587388-921642168.1569462522
Going to see if I have any luck.
Seems to have worked anyway… I’ve finally got moods. I’m not totally convinced but hey ho I got what I wanted.
