Is Plex Premium Music still a feature
I have noticed that in the last 6 months Plex is coding music incorrectly more and more,
I read posts that the Premium Music agent is missing, It is also missing on my server,
Is this the cause of the issue?
for agents is see:
Personal Media Artists TAB
Personal Media artists
Local Media artists
also
Last.FM TAB
Last.fm
Am I missing an agent? Do I need to find a new one to add to the server
I am running Win Server 2016.
I have had a plex pass for many years,
No, there is no more “Basic” vs. “Premium” music library. Take a look at this announcement for more info:
In my post I have the current agent settings.
  1. Is there a better setup for these?
  2. Is there a better agent to use for PMS.
  1. The settings under Agents are not relevant for newly created music libraries.
    All relevant settings are now available when you edit the library and go to the ‘Advanced’ tab.
    There, activate ‘Prefer local metadata’ if you want Plex to honor your embedded meta tags and set the rest according to your liking.
  2. All development is now happening in the new “music code”, which uses musicbrainz.org as its main data source (with allmusic.com and last.fm embellishments).
    If you want your library to use this code, you need to edit your music library and set both Scanner and Agent to ‘Plex Music’.
    But careful: Plex expects a folder structure of
    Music > Albumartist > Albumtitle > Tracks
    If your file organisation doesn’t conform to this, mismatches and general weirdness will ensue. i.e. it is now even more strict about file organisation than it used to.
Thanks for your help
