Server Version#: 1.21.2.3943 (Linuxserver docker on unRAID 6.9.0-rc2)
I see Plex running idle, then suddenly in the logs I see it reboot. Going to /web locally returns nothing. I can’t find anything in the logs causing a reboot. (Yes it’s split up into two, .1 is before the crash I assume.)
I’ve also had a few crashes before, right after this line: BPQ: [Starting] → [Processing] PlexLogs.zip (121.8 KB)
Edit: Yes I’ve tried the container from Plex itself, had the same issue. So I’m pretty sure it’s something to do with Plex itself, rather than the container.
Have you tried rebuilding the DB? I had a similar issue and after doing that it seems to be stable for 3 days and counting. It’s a pretty simple process, i copied my db to my windows box with winscp and rebuilt it there then copied it back over.
This suggestion is under the assumption that you migrated your data and DB when attempting to use a different docker, rather than starting new.
Yes, I’ve tried that already. Thanks for the suggestion though! Rebuilt it on the same unRAID machine, I’ve tried repairing it on Windows, but that gave me a gazillion SQLite errors while rebuilding.
I’ve set this one up completely new after I suspected that the DB was the issue, but clearly that isn’t the case.
Kind of a bump. I resorted to an extra container that restarts unhealthy containers, although I’d imagine this isn’t the intended solution. Haven’t come up with anything that can lead me to WHY it crashes either.
