Server Version#: v1.18.4.2171-ac2afe5f8 - Docker Docker Container (LinuxServer.io) x86_64 - build: linux-x86_64 debian - GMT -06:00
Player Version# : N/A
Plex Media Server.log (66.6 KB)
Since about a couple weeks ago I found that my Plex container running on unRAID 6.8.0 is stopped when I go to use it. I do have a backup set to run early in the morning, which stops containers, does the backup and restarts them. I believe the problem occurs then. If I restart the container, it fires up fine but almost every morning for the last couple of weeks the container is stopped.
plex container.log (1.6 KB)
Critical: libusb_init failed
^ appears in the docker container right before the container shuts down. Seems like an odd error message for a docker container.
Anyone have any ideas? I really don’t want to blow out my database.
EDIT: I have followed the database repair procedure outlined here… https://support.plex.tv/articles/201100678-repair-a-corrupt-database/ in hopes that fixes my issue. No corruption was detected but I still dumped and re-imported.
