I just noticed this today, not sure for how long this has been going already, but when I connect to Plex/Web locally (through the IP address), the web dashboard says I am connected remotely:
No, I am using Chrome and Safari (both with the same result).
I have my own local DNS Server (Unbound) and a hardware firewall by Fortinet.
I havenât seen this before and everything else appears to be running fine. When I start a stream, itâs being played back locally. Itâs just the WebUI that says the servers are remote.
You might have to create a few exemption rules in a locked-down DNS configuration, to allow Plexâs special way to use the DNS system (which is totally legit, but unusual).
Reading that as we speak. Especially interesting is the part where they talk about PFSense. PFSense also uses Unbound as its DNS component. So I may have to actually disable DNS Rebind checks there. Iâll look into it tomorrow and let you know.
Thanks, you probably pointed me in the right direction from the looks of it.
