Plex '--scan' operation is deprecated but PMS is still using it
Server Version#: 1.41.0.8930
Player Version#: N/A
My under standing is that the --scan operation has been depricated and should no longer be used. I notice that Plex is still using the --scan operation when the scan my library periodically setting is checked under Settings > Server > Library.
Aug 29, 2024 14:31:57.631 [138511688674104] DEBUG - Checking if time for scheduled update
Aug 29, 2024 14:31:57.632 [138511688674104] INFO - It's been 1800 seconds, so we're starting scheduled library update for section 13 (Home Videos)
Aug 29, 2024 14:31:57.632 [138511688674104] DEBUG - Library Updater: Requested that section 13 be updated, force=0, subdir= iTunes=0
Aug 29, 2024 14:31:57.632 [138511688674104] DEBUG - Library Updater: Queueing section 13
Aug 29, 2024 14:31:57.632 [138511688674104] INFO - It's been 1800 seconds, so we're starting scheduled library update for section 2 (Movies)
Aug 29, 2024 14:31:57.632 [138511688674104] DEBUG - Library Updater: Requested that section 2 be updated, force=0, subdir= iTunes=0
Aug 29, 2024 14:31:57.632 [138511688674104] DEBUG - Library Updater: Queueing section 2
Aug 29, 2024 14:31:57.632 [138511688674104] INFO - It's been 1499 seconds, so we're starting scheduled library update for section 4 (Music)
Aug 29, 2024 14:31:57.632 [138511688674104] DEBUG - Library Updater: Requested that section 4 be updated, force=0, subdir= iTunes=0
Aug 29, 2024 14:31:57.632 [138511688674104] DEBUG - Library Updater: Queueing section 4
Aug 29, 2024 14:31:57.632 [138511688674104] INFO - It's been 1494 seconds, so we're starting scheduled library update for section 14 (Photos)
Aug 29, 2024 14:31:57.632 [138511688674104] DEBUG - Library Updater: Requested that section 14 be updated, force=0, subdir= iTunes=0
Aug 29, 2024 14:31:57.632 [138511688674104] DEBUG - Library Updater: Queueing section 14
Aug 29, 2024 14:31:57.632 [138511688674104] INFO - It's been 1492 seconds, so we're starting scheduled library update for section 9 (Recorded Movies)
Aug 29, 2024 14:31:57.632 [138511688674104] DEBUG - Library Updater: Requested that section 9 be updated, force=0, subdir= iTunes=0
Aug 29, 2024 14:31:57.632 [138511688674104] DEBUG - Library Updater: Queueing section 9
Aug 29, 2024 14:31:57.632 [138511688674104] INFO - It's been 1492 seconds, so we're starting scheduled library update for section 5 (Recorded TV)
Aug 29, 2024 14:31:57.632 [138511688674104] DEBUG - Library Updater: Requested that section 5 be updated, force=0, subdir= iTunes=0
Aug 29, 2024 14:31:57.632 [138511688674104] DEBUG - Library Updater: Queueing section 5
Aug 29, 2024 14:31:57.632 [138511688674104] INFO - It's been 1492 seconds, so we're starting scheduled library update for section 1 (TV Shows)
Aug 29, 2024 14:31:57.632 [138511688674104] DEBUG - Library Updater: Requested that section 1 be updated, force=0, subdir= iTunes=0
Aug 29, 2024 14:31:57.633 [138511730617144] DEBUG - Activity: registered new activity 234b8776-f855-4ac2-8204-74b8dda9dced - "Scanning"
Aug 29, 2024 14:31:57.633 [138511730617144] DEBUG - Scanning section 13
Aug 29, 2024 14:31:57.633 [138511730617144] DEBUG - Activity: updated activity 234b8776-f855-4ac2-8204-74b8dda9dced - completed 0.0% - Scanning Home Videos
Aug 29, 2024 14:31:57.633 [138511730617144] DEBUG - Job was already killed, not killing again.
Aug 29, 2024 14:31:57.633 [138511730617144] DEBUG - [JobRunner] Job running: FFMPEG_EXTERNAL_LIBS='/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/7592546-570471557d92948f58893deb-linux-x86_64/' X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx "/usr/lib/plexmediaserver/Plex Media Scanner" --scan --refresh --section 13 --activity 234b8776-f855-4ac2-8204-74b8dda9dced
Given the operation is deprecated, the relevant PMS code that calls it should probably be cleaned up to refer to the new API functions instead.
