Plex seems to be deleting files
Server Version#: 1.26.0.5715
currently having an issue in which i will add some files to the directory and then after a day or so those files disappear, seemingly deleted. the files show up in the logs repeatedly but i can find no resource to help with understanding the logs at all. here is the entries i have found (minus ip) and the log it was in. if anyone could please help me understand what is happening it would be appreciated. there are 3 entries doing this. in this case its related to komi cant communicate season 2, episode 2. the other two is also happening to episode 2 for two other shows.
plex media scanner.log
May 03, 2022 01:45:01.893 [0x7f8688b38808] DEBUG - HTTP requesting PUT ip/activities/?percentComplete=%2B0%2E0600728169&subtitle=Komi%20Can%E2%80%99t%20Communicate%20-%20Season%202
May 03, 2022 01:45:01.893 [0x7f8683397b38] DEBUG - HTTP requesting GET ip/:/metadata/updateProgressMessage?message=Scanning%20Komi%20Can%E2%80%99t%20Communicate%2FSeason%202
May 03, 2022 01:45:01.894 [0x7f8683374b38] DEBUG - [HttpClient] HTTP/1.1 (0.0s) 200 response from PUT ip/activities/?percentComplete=%2B0%2E0600728169&subtitle=Komi%20Can%E2%80%99t%20Communicate%20-%20Season%202 (reused)
plex media scanner.3log
May 03, 2022 01:38:01.853 [0x7f877f24c808] DEBUG - HTTP requesting PUT http://ip/activities/?percentComplete=%2B0.0618750006&subtitle=Komi%20Can’t%20Communicate%20-%20Season%202
May 03, 2022 01:38:01.853 [0x7f8779a9bb38] DEBUG - HTTP requesting GET ip/:/metadata/updateProgressMessage?message=Scanning%20Komi%20Can%E2%80%99t%20Communicate%2FSeason%202
May 03, 2022 01:38:01.854 [0x7f8779a78b38] DEBUG - [HttpClient] HTTP/1.1 (0.0s) 200 response from PUT ip/activities/?percentComplete=%2B0%2E0618750006&subtitle=Komi%20Can%E2%80%99t%20Communicate%20-%20Season%202 (reused)
May 03, 2022 01:38:01.854 [0x7f8779a78b38] DEBUG - [HttpClient] HTTP/1.1 (0.0s) 200 response from GET ip/:/metadata/updateProgressMessage?message=Scanning%20Komi%20Can%E2%80%99t%20Communicate%2FSeason%202 (reused)
May 03, 2022 01:43:47.482 [0x7f877f24c808] DEBUG - Updating directory ‘Komi Can’t Communicate/Season 2’ (ID 11813) to time 2022-04-08 16:51:21.
plex media server.1.log
message=Scanning%20Komi%20Can%E2%80%99t%20Communicate (21 live) GZIP Signed-in Token
May 03, 2022 01:44:19.304 [0x7f1201417b38] DEBUG - Completed: [ip] 200 GET /:/metadata/updateProgressMessage?message=Scanning%20Komi%20Can%E2%80%99t%20Communicate (21 live) GZIP 0ms 195 bytes (pipelined: 229)
May 03, 2022 01:44:19.342 [0x7f11fc6afb38] DEBUG - Request: [ip (Loopback)] PUT /activities/?percentComplete=%2B0%2E0605875142&subtitle=Komi%20Can%E2%80%99t%20Communicate%20-%20Season%202 (21 live) GZIP Signed-in Token
May 03, 2022 01:44:19.342 [0x7f11fc4d0b38] DEBUG - Request: [ip (Loopback)] GET /:/metadata/updateProgressMessage?message=Scanning%20Komi%20Can%E2%80%99t%20Communicate%2FSeason%202 (21 live) GZIP Signed-in Token
May 03, 2022 01:44:19.343 [0x7f1201417b38] DEBUG - Completed: [ip] 200 GET /:/metadata/updateProgressMessage?message=Scanning%20Komi%20Can%E2%80%99t%20Communicate%2FSeason%202 (21 live) GZIP 0ms 195 bytes (pipelined: 116)
May 03, 2022 01:44:19.343 [0x7f12018c6b38] DEBUG - Completed: [ip] 200 PUT /activities/?percentComplete=%2B0%2E0605875142&subtitle=Komi%20Can%E2%80%99t%20Communicate%20-%20Season%202 (21 live) GZIP 0ms 416 bytes (pipelined: 230)
May 03, 2022 01:44:19.354 [0x7f11fbddcb38] DEBUG - Request: [ip (Loopback)] PUT /activities/?percentComplete=%2B0%2E0605875142&subtitle=Komi%20Can%E2%80%99t%20Communicate%20-%20Season%201 (21 live) GZIP Signed-in Token
May 03, 2022 01:44:19.354 [0x7f11fc543b38] DEBUG - Request: [ip (Loopback)] GET /:/metadata/updateProgressMessage?message=Scanning%20Komi%20Can%E2%80%99t%20Communicate%2FSeason%201 (21 live) GZIP Signed-in Token
May 03, 2022 01:44:19.355 [0x7f12018c6b38] DEBUG - Completed: [ip] 200 GET /:/metadata/updateProgressMessage?message=Scanning%20Komi%20Can%E2%80%99t%20Communicate%2FSeason%201 (21 live) GZIP 0ms 195 bytes (pipelined: 231)
May 03, 2022 01:44:19.355 [0x7f1201417b38] DEBUG - Completed: [ip] 200 PUT /activities/?percentComplete=%2B0%2E0605875142&subtitle=Komi%20Can%E2%80%99t%20Communicate%20-%20Season%201 (21 live) GZIP 0ms 416 bytes (pipelined: 117)
this repeats again later in the log. then this repeats in logs 2, 3, 4, 5 for media server logs.
i have tested the files to confirm there is nothing wrong with them but for whatever reason they just keep getting beleted and i can only assume that plex is doing it somehow.
Could you show a screen capture showing both the of show folder, the season folders as well as the files in season 2 directory (ls -la)
you will have to give me some time for that. server isnt mine and the owner told me to figure it out because hes lazy. also its a remote machine in linux so he cant do it until he gets off work. anything else we can check for now while im waiting?
A zip of the server logs could also help, instead of the snips provided
here we are
Plex_Media_Server_Logs_2022-05-03_03-45-40.zip (4.9 MB)
Sadly logs rolled over, so no traces of that show in the scanners log
Edit: So we wait for the screen capture
