Plex Seperate Libraries
Hi All,
Just wondering if there is a way to create separate library groups, I’ve got TV shows, Cartoons and Anime for example but would like them to be split so when trying to create the home page I can have “Recently added TV Shows” , “Recently added Cartoons” and “Recently added Anime” and the same with Movies and Anime Movies.
Maybe rather than it sorting Recently added then the Library group it does the name we have set for each. Is this a feature or could this be added in later on as a feature as it would help sorting out libraries and feeds alot.
Cheers,
Pyro
Based on the current design, the overall home screen will group content from different libraries in those hubs. I believe the idea was to avoid overloading the page with too many hubs.
If you want to access hubs like “recently added” etc. for individual libraries, you currently can only get there via the “Recommended” tab of that library.
Yea, I just had to re-build my whole library, I thought I had it setup separately before the rebuild but now I cant seem to split them. Its got me baffled and I cant seem to work out how I had it before.
