Plex Server auf Interface binden
Hallo Ihr Lieben,
ich kann mein Plex Server nicht mehr auf ein Interface binden.
Server Version#: 1.18.3.2156
Meine Preferences.xml Datei hat folgenden Inhalt:
cat /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Preferences.xml
<?xml version="1.0" encoding="utf-8"?>
<Preferences allowedNetworks="192.168.0.0/255.255.0.0" MachineIdentifier="99258f29-1ff8-4c05-9f86-9e28d27bb755" ProcessedMachineIdentifier="fc1ae6ac3f40c86dfa03375bb6f966450ce18632" AcceptedEULA="1" FriendlyName="plex.intern.example.com" PlexOnlineMail="sharbich@t-online.de" PlexOnlineToken="XXXYYYZZZ" PlexOnlineUsername="xyz" PublishServerOnPlexOnlineKey="1" DlnaClientPreferences="IP=192.168.120.20,DirectPlay=true,DirectStream=true,LocalResolution=1920x1080,RemoteResolution=1280x720,OnlineResolution=1280x720,LocalVideoQuality=74,RemoteVideoQuality=49,OnlineVideoQuality=49,SubtitleSize=100,AudioBoost=100,MusicBitrate=320" DlnaDefaultProtocolInfo="" CinemaTrailersType="0" FSEventLibraryUpdatesEnabled="1" DlnaAnnouncementLeaseTime="1800" GdmEnabled="0" LastAutomaticMappedPort="10114" DlnaDescriptionIcons="" DlnaEnabled="1" ManualPortMappingMode="1" ManualPortMappingPort="32400" allowMediaDeletion="1" autoScanMusicSections="1" AnonymousMachineIdentifier="6f3f90a6-fe87-497c-a3ba-2304a4bcb3ee" GracenoteUser="WEcxA2bfKXOe8+JNj3FWh5LiWp1YxfIzvpKNXobK0mDJkh4PuHRxfOwVAQX2q+GPK60+t4SJXFqQzSY280n8Iy6nrkXExGBml7Rp4Z4/EwdWtstAqeHmY23P1M7haVWuQKx7TX7MT4pOIRkWgeqgXLRVnljem7Um8zQAvp74lBABbrVIJiOrfPsBXNua4HlzYLT/aA==" CertificateVersion="2" PlexOnlineHome="1" ScheduledLibraryUpdateInterval="86400" ScheduledLibraryUpdatesEnabled="1" MetricsEpoch="1" agentAutoEnabled.com.plexapp.agents.lastfm.Albums.com.plexapp.agents.lyricfind="1" agentAutoEnabled.com.plexapp.agents.plexmusic.Albums.com.plexapp.agents.lyricfind="1" LanguageInCloud="1" CloudSyncNeedsUpdate="0" FSEventLibraryPartialScanEnabled="1" watchMusicSections="1" PubSubServerPing="77" PubSubServer="139.162.158.105" OldestPreviousVersion="legacy" DlnaDeviceDiscoveryInterval="5" PubSubServerRegion="fra" secureConnections="1" customCertificateKey="" customCertificatePath="" ServerBindInterface="bond0.120" CertificateUUID="3e8aaa2e0ae4451ab72ab73f79ef46e5" PreferredNetworkInterface="bond0.120" DvrIncrementalEpgLoader="0" EnableIPv6="0" LanNetworksBandwidth="192.168.0.0/255.255.0.0"/>
Der Plex Media Server lauscht auf jedes Interface:
netstat -tulpn | egrep "Plex"
tcp        0      0 127.0.0.1:37829         0.0.0.0:*               LISTEN      23771/Plex Plug-in
tcp        0      0 0.0.0.0:32400           0.0.0.0:*               LISTEN      23661/Plex Media Se
tcp        0      0 127.0.0.1:32401         0.0.0.0:*               LISTEN      23661/Plex Media Se
tcp        0      0 0.0.0.0:32469           0.0.0.0:*               LISTEN      23736/Plex DLNA Ser
tcp        0      0 0.0.0.0:1208            0.0.0.0:*               LISTEN      23736/Plex DLNA Ser
tcp        0      0 127.0.0.1:32600         0.0.0.0:*               LISTEN      23727/Plex Tuner Se
tcp        0      0 127.0.0.1:43705         0.0.0.0:*               LISTEN      23813/Plex Plug-in
tcp        0      0 127.0.0.1:35263         0.0.0.0:*               LISTEN      23676/Plex Plug-in
udp        0      0 192.168.150.20:59661    0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:6437            0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 0.0.0.0:14755           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 192.168.190.2:47577     0.0.0.0:*                           23661/Plex Media Se
udp        0      0 192.168.120.20:43555    0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:2824            0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 0.0.0.0:15168           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 192.168.110.20:35834    0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:7530            0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 192.168.20.30:36312     0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:3641            0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 0.0.0.0:11931           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 192.168.20.25:40943     0.0.0.0:*                           23661/Plex Media Se
udp        0      0 192.168.130.20:49260    0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:13072           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 192.168.20.28:41831     0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:50092           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 0.0.0.0:5047            0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 0.0.0.0:13308           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 192.168.20.20:37942     0.0.0.0:*                           23661/Plex Media Se
udp        0      0 192.168.140.20:58622    0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:10056           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 0.0.0.0:1900            0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 0.0.0.0:1901            0.0.0.0:*                           23661/Plex Media Se
udp        0      0 0.0.0.0:42914           0.0.0.0:*                           23736/Plex DLNA Ser
udp        0      0 192.168.20.26:38869     0.0.0.0:*                           23661/Plex Media Se
Was mache ich nur falsch?
Lieben Gruß von Stefan Harbich
Wie äußert sich das? bzw. was genau erwartest du wie sich Plex verhält?
In deiner preferences.xml findet sich dieser Eintrag PreferredNetworkInterface="bond0.120"
Achte auf die Namensgebung: da steht nur “Preferred” (also “bevorzugt”). Es steht nicht da “binde Plex exklusiv an Interface x”.
Hab gerade eine Rückmeldung erhalten: das ist ein Bug der umgehend gefixt wird.
Was wäre denn der richte Eintrag in der “preferences.xml” um das Interface fest zu binden?
Einen solchen gibt es schlicht nicht.
Hallo OttoKerner,
so einen muss es aber mal gegeben haben. Siehe in meiner obigen Preferences.xml Datei.
ServerBindInterface=""
Was sagt dieser Befehl aus?
Das ist ein Überbleibsel einer älteren PMS Version und tut gar nichts mehr. (Es tat genau das Gleiche wie PreferredNetworkInterface= hat aber viele Nutzer verwirrt, bzw. falsche Erwartungen geweckt. Deshalb wurde es durch PreferredNetworkInterface= ersetzt.)
