Plex server failed with result signal
Hi there,
I’m new here and just yesterday I installed omv on my westerndigital mycloud home. everything perfect apart from plex, with which I have several problems. yesterday it gave me some errors and looking on the internet I solved practically everything and finally I managed to install it, the problem now occurs after I enabled it from the webgui and then restarted the nas. the error it gives me is plexmediaserver.service: failed with result ‘signal’
in fact from the dashboard it marks me the green dot on activated and red on on running.
the full message of error is:
systemctl status plexmediaserver.service
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/plexmediaserver.service.d
└─db_folder.conf
Active: failed (Result: signal) since Mon 2020-06-08 12:24:24 CEST; 5min ago
Main PID: 3574 (code=killed, signal=ABRT)
Jun 08 12:24:19 wdnas systemd[1]: plexmediaserver.service: Failed with result 'signal'.
Jun 08 12:24:24 wdnas systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
Jun 08 12:24:24 wdnas systemd[1]: Stopped Plex Media Server.
Jun 08 12:24:24 wdnas systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Jun 08 12:24:24 wdnas systemd[1]: Failed to start Plex Media Server.
Jun 08 12:24:24 wdnas systemd[1]: plexmediaserver.service: Unit entered failed state.
Jun 08 12:24:24 wdnas systemd[1]: plexmediaserver.service: Failed with result 'signal'.
journal -xe
Jun 08 12:24:09 wdnas Plex Media Server[3426]: terminate called after throwing an instance of 'std::runtime_error'
Jun 08 12:24:09 wdnas Plex Media Server[3426]:   what():  Codecs: Initialize: 'boost::filesystem::create_directory: Too many levels of symbolic links: "/srv/dev-sataa24/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/99c90e0-3095-linux-aarch64"'
Jun 08 12:24:09 wdnas systemd[1]: plexmediaserver.service: Main process exited, code=killed, status=6/ABRT
Jun 08 12:24:09 wdnas systemd[1]: plexmediaserver.service: Unit entered failed state.
Jun 08 12:24:09 wdnas systemd[1]: plexmediaserver.service: Failed with result 'signal'.
Jun 08 12:24:09 wdnas systemd[1]: Started Beep after system start.
-- Subject: Unit openmediavault-beep-up.service has finished start-up
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- Unit openmediavault-beep-up.service has finished starting up.
-- The start-up result is done.
Jun 08 12:24:09 wdnas systemd[1]: Startup finished in 4.932s (kernel) + 5min 10.147s (userspace) = 5min 15.080s.
-- Subject: System start-up is now complete
-- All system services necessary queued for starting at boot have been
-- successfully started. Note that this does not mean that the machine is
-- now idle as services might still be busy with completing start-up.
-- Kernel start-up required 4932306 microseconds.
-- Initial RAM disk start-up required INITRD_USEC microseconds.
-- Userspace start-up required 310147996 microseconds.
Jun 08 12:24:14 wdnas systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
Jun 08 12:24:14 wdnas systemd[1]: Stopped Plex Media Server.
-- Subject: Unit plexmediaserver.service has finished shutting down
-- Unit plexmediaserver.service has finished shutting down.
Jun 08 12:24:14 wdnas systemd[1]: Starting Plex Media Server...
-- Subject: Unit plexmediaserver.service has begun start-up
-- Unit plexmediaserver.service has begun starting up.
Jun 08 12:24:14 wdnas systemd[1]: Started Plex Media Server.
-- Subject: Unit plexmediaserver.service has finished start-up
-- Unit plexmediaserver.service has finished starting up.
Jun 08 12:24:14 wdnas Plex Media Server[3556]: terminate called after throwing an instance of 'std::runtime_error'
Jun 08 12:24:14 wdnas Plex Media Server[3556]:   what():  Codecs: Initialize: 'boost::filesystem::create_directory: Too many levels of symbolic links: "/srv/dev-sataa24/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/99c90e0-3095-linux-aarch64"'
Jun 08 12:24:14 wdnas systemd[1]: plexmediaserver.service: Main process exited, code=killed, status=6/ABRT
Jun 08 12:24:14 wdnas systemd[1]: plexmediaserver.service: Unit entered failed state.
Jun 08 12:24:14 wdnas systemd[1]: plexmediaserver.service: Failed with result 'signal'.
Jun 08 12:24:19 wdnas systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
Jun 08 12:24:19 wdnas systemd[1]: Stopped Plex Media Server.
Jun 08 12:24:19 wdnas systemd[1]: Starting Plex Media Server...
Jun 08 12:24:19 wdnas systemd[1]: Started Plex Media Server.
Jun 08 12:24:19 wdnas Plex Media Server[3574]: terminate called after throwing an instance of 'std::runtime_error'
Jun 08 12:24:19 wdnas Plex Media Server[3574]:   what():  Codecs: Initialize: 'boost::filesystem::create_directory: Too many levels of symbolic links: "/srv/dev-sataa24/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/99c90e0-3095-linux-aarch64"'
Jun 08 12:24:19 wdnas systemd[1]: plexmediaserver.service: Main process exited, code=killed, status=6/ABRT
Jun 08 12:24:19 wdnas systemd[1]: plexmediaserver.service: Unit entered failed state.
-- Subject: Unit plexmediaserver.service has failed
-- Unit plexmediaserver.service has failed.
-- The result is failed.
omv version: 4.1.23-1
debian version: 9
openmediavault-plexmediaserver version 3.8.2
also for this error I tried to search online and make several tests (reset permissions etc …) but the problem remains, even uninstalling, deleting the directory and then reinstalling plex from scratch, the problem remains.
what can I do?
