Plex server "indirect" connection, TrueNAS & pfSense
Server Version#: 1.1.14
Player Version#: Connecting via multiple players & web player
The server is running in a TrueNAS container with an internal container IP of 172.16.1.2:32400 and a local IP address of 192.168.4.14:32400. On the Internet it can be found at 45.19.23.43:3290
I don’t know if it makes a difference, but the Plex Remote Access settings page shows the container IP as opposed to the local IP.
When I check the server stats, it shows I have an indirect connection. When I look at the relay it shows my server is fully accessible from the Internet.
My content is fully accessible both on local LAN and the Internet, but that ‘!’ is giving me a bad case of Forrest Whitacre eye so it needs to get fixed.
I’m running pfSense 2.7.2 with an override of:
server:
private-domain: "plex.direct"
in the DNS resolver settings.
I completely turned off DNS rebinding protection, for testing and there was no difference.
Looking for anything else that may be able to resolve this issue.
This should probably be in the remote connection section. If you turn off relay can you get to your content outside your network? Im not familiar with pfsense anymore, haven’t used it in a long time. Check that your ports are open at https://canyouseeme.org/
Can you turn off relay without turning off remote access?
Yes relay is only used if you can’t connect directly and its throttled to 2Mbps.
Okay, how do I do that? It doesn’t seem to be exposed in the UI.
