Plex server not working anymore after container upgrade from 1.29.0.6244 to 1.29.1.6316 and upwards
Check your PM
I had to go look at the source code.
What you show here:
Export: (main)…Error relocating /usr/lib/plexmediaserver/Plex Media Server: drmGetDevices2: symbol not found
Error 127 from Plex SQLite while exporting com.plexapp.plugins.library.db
Could not successfully export the main database to repair it. Please try restoring a backup.
Tells me the contents of /usr/lib/plemediaserver/lib is severely corrupt.
I can help you fix it.
I now understand why the container isn’t starting
Finally, I managed to get out of the trap.
I don’t know why, but from version 1.29.1, you HAVE TO add the Plex library path in the LD-LIBRARY_PATH inside the container.
See here : Plex not starting (symbol not found) · Issue #335 · linuxserver/docker-plex · GitHub
I found this error message from the CLI : docker logs #IDofTheContainer#
I’ll close this case if I’m able to upgrade my new container from 1.29.2.6364 (current version) to the 1.30.
I’ll get you posted.
Everything is fine, my container is OK, I upgraded like a charm to 1.30.0.6486.
Fixed !
