[Help] PMS container cannot start
Server Version#: 1.41.7.9799-5bce000f7
Player Version#: N/A
OS: Ubuntu 24.04.2 LTS
Docker version: 28.1.1, build 4eba377
My PMS container cannot start since yesterday.
I have tried to downgrade to docker tag 1.41.6.9685-d301f511a but it didn’t help.
Container log:
$ sudo docker logs plex
[sudo] password for janus:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 40-plex-first-run: executing...
Plex Media Server first run setup complete
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: executing...
[cont-init.d] 45-plex-hw-transcode-and-connected-tuner: exited 0.
[cont-init.d] 50-plex-update: executing...
Attempting to upgrade to: 1.41.7.9799-5bce000f7
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100 79.3M  100 79.3M    0     0  89.7M      0 --:--:-- --:--:-- --:--:-- 89.7M
Selecting previously unselected package plexmediaserver.
(Reading database ... 7274 files and directories currently installed.)
Preparing to unpack /tmp/plexmediaserver.deb ...
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Custom environment detected.  Skipping preinstallation validation.
Unpacking plexmediaserver (1.41.7.9799-5bce000f7) ...
Setting up plexmediaserver (1.41.7.9799-5bce000f7) ...
PlexMediaServer install: Custom environment detected.  Skipping postinstallation tasks. Continuing.
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting Plex Media Server.
[services.d] done.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
s6-svwait: fatal: timed out
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
Plex Media Server is already running. Will not start...
Stopping Plex Media Server.
kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec ... or kill -l [sigspec]
/config/Library/Application Support/Plex Media Server/Logs/Plex Media Server.log
$ cat Plex\ Media\ Server.log
May 22, 2025 11:04:51.455 [126976193919800] INFO - Plex Media Server v1.41.7.9799-5bce000f7 - Docker Docker Container x86_64 - build: linux-x86_64 debian - GMT 00:00
May 22, 2025 11:04:51.455 [126976193919800] INFO - Linux version: 6.8.0-60-generic, language: en-US
May 22, 2025 11:04:51.456 [126976193919800] INFO - Processor: 16-core 13th Gen Intel(R) Core(TM) i5-1340P
May 22, 2025 11:04:51.456 [126976193919800] INFO - Compiler is - Clang 11.0.1 (https://plex.tv 9b997da8e5b47bdb4a9425b3a3b290be393b4b1f)
May 22, 2025 11:04:51.456 [126976193919800] INFO - /usr/lib/plexmediaserver/Plex Media Server
May 22, 2025 11:06:08.103 [126976196508304] INFO - SQLITE3:0x80000001, 283, recovered 36454519 frames from WAL file /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
May 22, 2025 11:06:08.584 [126976196508304] INFO - [CERT/OCSP] Successfully retrieved response from cache.
May 22, 2025 11:06:08.585 [126976196508304] ERROR - [CERT] Found a user-provided certificate, but couldn't install it.
May 22, 2025 11:06:08.585 [126976196508304] INFO - Running migrations. (EPG 0)
May 22, 2025 11:06:30.803 [126976196508304] INFO - SQLITE3:0x80000001, 283, recovered 108 frames from WAL file /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db-wal
May 22, 2025 11:06:30.807 [126976196508304] INFO - Running migrations. (EPG 0)
May 22, 2025 11:06:30.810 [126975877290808] INFO - Preemptively preparing driver imd for GPU Intel Raptor Lake-P [Iris Xe Graphics]
May 22, 2025 11:06:30.811 [126975877290808] INFO - Preemptively preparing driver icr for GPU Intel Raptor Lake-P [Iris Xe Graphics]
compose.yaml
# plex/compose.yaml
include:
  - ./volumes.yaml
services:
  plex:
    image: "plexinc/pms-docker:plexpass"
    container_name: plex
    deploy:
      resources:
        limits:
          memory: 4G
    hostname: NUC13
    devices:
      - "/dev/dri:/dev/dri"
      - /dev/bus/usb:/dev/bus/usb # to silence the error "Critical: libusb_init failed"
    environment:
      - PLEX_UID=1050
      - PLEX_GID=1050
      - TZ="Europe/London"
      - PLEX_CLAIM="***REDACTED***"
      - 'LANG=en_US.UTF-8'
      - ADVERTISE_IP=https://plex.example.com,https://plex.example.com,http://10.27.0.50:32400
    volumes:
      - "./config:/config:rw"
      - type: tmpfs # Optional: 10GB of memory, reduces SSD/SD Card wear
        target: /transcode
      - type: volume
        source: private
        target: /mnt/private
      - type: volume
        source: backup
        target: /mnt/backup
        volume:
          subpath: backup
      - type: volume
        source: media_Movies
        target: /mnt/media/Movies
      - type: volume
        source: media_Movies_4K
        target: /mnt/media/Movies_4K
      - type: volume
        source: media_Music
        target: /mnt/media/Music
      - type: volume
        source: media_Music_Videos
        target: /mnt/media/Music_Videos
      - type: volume
        source: media_TV_Shows
        target: /mnt/media/TV_Shows
      - type: volume
        source: media_Videos
        target: /mnt/media/Videos
    ports:
      - 32400:32400/tcp
      - 8324:8324/tcp
      - 32469:32469/tcp
      - 32410:32410/udp
      - 32412:32412/udp
      - 32413:32413/udp
      - 32414:32414/udp
    restart: unless-stopped
    labels:
      - "com.centurylinklabs.watchtower.enable=false"
After restarting the PMS, I have got a respond from the web interface finally.
<Response code="503" title="Maintenance" status="Plex Media Server is currently running startup maintenance tasks."/>
Would it recover later?
After a long while, it did come back but it failed again not long after I connected to it from web. I restarted it and the cycle repeated a couple times.
I rolled back to tag “public” now. Let’s see how it goes.
I suspect data corruption was the culprit. After restored to an older version of Library files, it seems stable now. However, the container log is spammed by a line No data written!!
Here is the log Plex Media Server.log
May 22, 2025 17:44:09.690 [129098826496824] INFO - Plex Media Server v1.41.6.9685-d301f511a - Docker Docker Container x86_64 - build: linux-x86_64 debian - GMT 00:00
May 22, 2025 17:44:09.691 [129098826496824] INFO - Linux version: 6.8.0-60-generic, language: en-US
May 22, 2025 17:44:09.691 [129098826496824] INFO - Processor: 16-core 13th Gen Intel(R) Core(TM) i5-1340P
May 22, 2025 17:44:09.691 [129098826496824] INFO - Compiler is - Clang 11.0.1 (https://plex.tv 9b997da8e5b47bdb4a9425b3a3b290be393b4b1f)
May 22, 2025 17:44:09.691 [129098826496824] INFO - /usr/lib/plexmediaserver/Plex Media Server
May 22, 2025 17:44:09.702 [129098829068944] INFO - SQLITE3:0x80000001, 283, recovered 11 frames from WAL file /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
May 22, 2025 17:44:09.750 [129098829068944] INFO - [CERT/OCSP] Successfully retrieved response from cache.
May 22, 2025 17:44:09.750 [129098829068944] ERROR - [CERT] Found a user-provided certificate, but couldn't install it.
May 22, 2025 17:44:09.750 [129098829068944] INFO - Running migrations. (EPG 0)
May 22, 2025 17:44:09.851 [129098829068944] INFO - Running migrations. (EPG 0)
May 22, 2025 17:44:09.853 [129098821737272] INFO - CodecManager: obtaining decoder 'msmpeg4v1'
May 22, 2025 17:44:10.140 [129098752015160] INFO - CodecManager: obtaining decoder 'wmav1'
May 22, 2025 17:44:10.213 [129098752015160] INFO - CodecManager: obtaining decoder 'h264'
May 22, 2025 17:44:10.379 [129098752015160] INFO - CodecManager: obtaining decoder 'wmapro'
May 22, 2025 17:44:10.445 [129098752015160] INFO - CodecManager: obtaining decoder 'mpeg4'
May 22, 2025 17:44:10.556 [129098752015160] INFO - CodecManager: obtaining decoder 'wmv3'
May 22, 2025 17:44:10.638 [129098752015160] INFO - CodecManager: obtaining decoder 'wavpack'
May 22, 2025 17:44:10.710 [129098752015160] INFO - CodecManager: obtaining decoder 'cook'
May 22, 2025 17:44:10.782 [129098752015160] INFO - CodecManager: obtaining decoder 'mpeg1video'
May 22, 2025 17:44:10.847 [129098829068944] WARN - Database file not found at preference location: /mnt/media/Tunes/iTunes Library.xml (No such file or directory)
May 22, 2025 17:44:10.863 [129098752015160] INFO - CodecManager: obtaining decoder 'h263'
May 22, 2025 17:44:10.998 [129098777131832] WARN - [DatabaseFixups] Held transaction for too long (/home/runner/_work/plex-media-server/plex-media-server/Library/MetadataCollection.cpp:519): 0.170000 seconds
May 22, 2025 17:44:11.088 [129098752015160] INFO - CodecManager: obtaining decoder 'flv'
May 22, 2025 17:44:11.176 [129098752015160] INFO - CodecManager: obtaining decoder 'vp6f'
May 22, 2025 17:44:11.248 [129098752015160] INFO - CodecManager: obtaining decoder 'mpeg2video'
May 22, 2025 17:44:11.321 [129098752015160] INFO - CodecManager: obtaining decoder 'msmpeg4'
May 22, 2025 17:44:11.389 [129098813745976] WARN - [EventSourceClient/pubsub/178.79.180.168:443] MyPlex: attempted a reachability check but we're not yet mapped.
May 22, 2025 17:44:11.392 [129098752015160] INFO - CodecManager: obtaining decoder 'rv40'
May 22, 2025 17:44:11.475 [129098710170424] INFO - CodecManager: obtaining encoder 'aac'
May 22, 2025 17:44:11.546 [129098811636536] INFO - [CERT/OCSP] Successfully retrieved response from cache.
May 22, 2025 17:44:11.546 [129098811636536] ERROR - [CERT] Found a user-provided certificate, but couldn't install it.
May 22, 2025 17:44:11.572 [129098752015160] INFO - CodecManager: obtaining decoder 'mp2'
May 22, 2025 17:44:11.655 [129098710170424] INFO - CodecManager: obtaining decoder 'wmv1'
May 22, 2025 17:44:11.737 [129098752015160] INFO - CodecManager: obtaining decoder 'vc1'
May 22, 2025 17:44:11.895 [129098752015160] INFO - CodecManager: obtaining decoder 'indeo5'
May 22, 2025 17:44:11.976 [129098710170424] INFO - CodecManager: obtaining decoder 'svq1'
May 22, 2025 17:44:12.050 [129098710170424] INFO - CodecManager: obtaining decoder 'hevc'
May 22, 2025 17:44:12.130 [129098710170424] INFO - CodecManager: obtaining decoder 'indeo4'
May 22, 2025 17:44:12.218 [129098752015160] INFO - CodecManager: obtaining decoder 'qdraw'
May 22, 2025 17:44:12.285 [129098824313656] WARN - JobManager: Could not find job for handle 434
May 22, 2025 17:44:12.330 [129098710170424] INFO - CodecManager: obtaining decoder 'wmav2'
May 22, 2025 17:44:12.459 [129098710170424] INFO - CodecManager: obtaining decoder 'msmpeg4v2'
May 22, 2025 17:44:12.516 [129098824313656] WARN - JobManager: Could not find job for handle 437
May 22, 2025 17:44:12.557 [129098752015160] INFO - CodecManager: obtaining decoder 'indeo3'
May 22, 2025 17:44:12.821 [129098752015160] INFO - CodecManager: obtaining decoder 'aac'
May 22, 2025 17:44:12.893 [129098752015160] INFO - CodecManager: obtaining decoder 'qtrle'
May 22, 2025 17:44:12.904 [129098824313656] WARN - JobManager: Could not find job for handle 508
May 22, 2025 17:44:12.957 [129098710170424] INFO - CodecManager: obtaining decoder 'qdm2'
May 22, 2025 17:44:13.024 [129098752015160] INFO - CodecManager: obtaining decoder 'mp3'
May 22, 2025 17:44:13.097 [129098710170424] INFO - CodecManager: obtaining decoder 'wmv2'
May 22, 2025 17:44:13.129 [129098824313656] WARN - JobManager: Could not find job for handle 568
May 22, 2025 17:44:13.129 [129098824313656] WARN - JobManager: Could not find job for handle 533
May 22, 2025 17:44:13.171 [129098710170424] INFO - CodecManager: obtaining decoder 'svq3'
May 22, 2025 17:44:13.247 [129098710170424] INFO - CodecManager: obtaining decoder 'ac3'
May 22, 2025 17:44:13.312 [129098710170424] INFO - CodecManager: obtaining encoder 'libx264'
May 22, 2025 17:44:13.408 [129098752015160] INFO - CodecManager: obtaining decoder 'vp9'
May 22, 2025 17:44:13.499 [129098752015160] INFO - CodecManager: obtaining decoder 'dca'
May 22, 2025 17:44:13.567 [129098752015160] INFO - CodecManager: obtaining decoder 'cinepak'
May 22, 2025 17:44:13.744 [129098752015160] INFO - Preemptively preparing driver imd for GPU Intel Raptor Lake-P [Iris Xe Graphics]
May 22, 2025 17:44:13.745 [129098752015160] INFO - Preemptively preparing driver icr for GPU Intel Raptor Lake-P [Iris Xe Graphics]
May 22, 2025 17:44:13.854 [129098824313656] WARN - JobManager: Could not find job for handle 616
May 22, 2025 17:44:14.475 [129098758146872] INFO - Refreshing paths watched by LibraryUpdateManager
May 22, 2025 17:44:14.478 [129098824313656] WARN - JobManager: Could not find job for handle 502
May 22, 2025 17:44:17.229 [129098813745976] WARN - [EventSourceClient/pubsub/176.58.107.84:443] MyPlex: attempted a reachability check but we're not yet mapped.
May 22, 2025 17:44:22.118 [129098713058104] WARN - [Req#e1] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.118 [129098708060984] WARN - [Req#e4] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.118 [129098713058104] WARN - [Req#e1] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.118 [129098708060984] WARN - [Req#e4] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.171 [129098677713720] WARN - [Req#e9] SLOW QUERY: It took 450.000000 ms to retrieve 11 items.
May 22, 2025 17:44:22.190 [129098681932600] WARN - [Req#e7] SLOW QUERY: It took 580.000000 ms to retrieve 13 items.
May 22, 2025 17:44:22.209 [129098725755704] WARN - [Req#e6] SLOW QUERY: It took 620.000000 ms to retrieve 13 items.
May 22, 2025 17:44:22.212 [129098745322296] WARN - [Req#e2] SLOW QUERY: It took 620.000000 ms to retrieve 13 items.
May 22, 2025 17:44:22.212 [129098727865144] WARN - [Req#e5] SLOW QUERY: It took 650.000000 ms to retrieve 13 items.
May 22, 2025 17:44:22.216 [129098679823160] WARN - [Req#e8] SLOW QUERY: It took 670.000000 ms to retrieve 13 items.
May 22, 2025 17:44:22.309 [129098675604280] ERROR - [Req#fc] Unknown metadata type: folder
May 22, 2025 17:44:22.309 [129098675604280] WARN - [Req#fc] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.309 [129098675604280] WARN - [Req#fc] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.348 [129098703633208] ERROR - [Req#116] Unknown metadata type: folder
May 22, 2025 17:44:22.349 [129098703633208] WARN - [Req#116] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.349 [129098703633208] WARN - [Req#116] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.385 [129098713058104] WARN - [Req#e1] SLOW QUERY: It took 210.000000 ms to retrieve 50 items.
May 22, 2025 17:44:22.494 [129098745322296] WARN - [Req#11e] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:44:22.494 [129098745322296] WARN - [Req#11e] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.494 [129098745322296] WARN - [Req#11e] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.496 [129098727865144] ERROR - [Req#118] Unknown metadata type: folder
May 22, 2025 17:44:22.496 [129098679823160] WARN - [Req#11c] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:44:22.496 [129098725755704] ERROR - [Req#11d] Unknown metadata type: folder
May 22, 2025 17:44:22.496 [129098679823160] WARN - [Req#11c] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.496 [129098679823160] WARN - [Req#11c] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.497 [129098727865144] WARN - [Req#118] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.497 [129098725755704] WARN - [Req#11d] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.497 [129098727865144] WARN - [Req#118] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.497 [129098725755704] WARN - [Req#11d] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.511 [129098701179704] ERROR - [Req#121] Unknown metadata type: folder
May 22, 2025 17:44:22.511 [129098701179704] WARN - [Req#121] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.511 [129098701179704] WARN - [Req#121] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.516 [129098672663352] ERROR - [Req#11a] Unknown metadata type: folder
May 22, 2025 17:44:22.516 [129098672663352] WARN - [Req#11a] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.516 [129098672663352] WARN - [Req#11a] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.629 [129098708060984] ERROR - [Req#129] Unknown metadata type: folder
May 22, 2025 17:44:22.629 [129098708060984] WARN - [Req#129] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.629 [129098708060984] WARN - [Req#129] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.673 [129098713058104] WARN - [Req#12b] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:44:22.673 [129098713058104] WARN - [Req#12b] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.673 [129098713058104] WARN - [Req#12b] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.678 [129098727865144] ERROR - [Req#12a] Unknown metadata type: folder
May 22, 2025 17:44:22.678 [129098727865144] WARN - [Req#12a] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:22.679 [129098727865144] WARN - [Req#12a] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:23.006 [129098725755704] ERROR - [Req#130] Unknown metadata type: folder
May 22, 2025 17:44:23.006 [129098725755704] WARN - [Req#130] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:23.006 [129098725755704] WARN - [Req#130] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:23.247 [129098764475192] WARN - NAT: PMP, got an error: Not Supported by gateway.
May 22, 2025 17:44:23.309 [129098675604280] WARN - [Req#131] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:44:23.309 [129098675604280] WARN - [Req#131] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:23.309 [129098675604280] WARN - [Req#131] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.560 [129098725755704] ERROR - [Req#1c0] Unknown metadata type: folder
May 22, 2025 17:44:26.560 [129098725755704] WARN - [Req#1c0] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.560 [129098725755704] WARN - [Req#1c0] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.602 [129098672663352] ERROR - [Req#1bd] Unknown metadata type: folder
May 22, 2025 17:44:26.602 [129098672663352] WARN - [Req#1bd] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.602 [129098672663352] WARN - [Req#1bd] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.695 [129098679823160] WARN - [Req#1c6] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:44:26.695 [129098679823160] WARN - [Req#1c6] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.695 [129098679823160] WARN - [Req#1c6] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.696 [129098708060984] WARN - [Req#1c4] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:44:26.696 [129098708060984] WARN - [Req#1c4] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.696 [129098681932600] ERROR - [Req#1c3] Unknown metadata type: folder
May 22, 2025 17:44:26.696 [129098708060984] WARN - [Req#1c4] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.697 [129098675604280] ERROR - [Req#1c5] Unknown metadata type: folder
May 22, 2025 17:44:26.697 [129098713058104] ERROR - [Req#1bb] Unknown metadata type: folder
May 22, 2025 17:44:26.698 [129098681932600] WARN - [Req#1c3] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.698 [129098681932600] WARN - [Req#1c3] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.698 [129098727865144] ERROR - [Req#1ba] Unknown metadata type: folder
May 22, 2025 17:44:26.699 [129098675604280] WARN - [Req#1c5] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.699 [129098713058104] WARN - [Req#1bb] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.699 [129098675604280] WARN - [Req#1c5] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.699 [129098727865144] WARN - [Req#1ba] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.699 [129098713058104] WARN - [Req#1bb] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.699 [129098727865144] WARN - [Req#1ba] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.743 [129098727865144] WARN - [Req#1ba] SLOW QUERY: It took 230.000000 ms to retrieve 24 items.
May 22, 2025 17:44:26.748 [129098713058104] WARN - [Req#1bb] SLOW QUERY: It took 230.000000 ms to retrieve 24 items.
May 22, 2025 17:44:26.763 [129098681932600] WARN - [Req#1c3] SLOW QUERY: It took 320.000000 ms to retrieve 24 items.
May 22, 2025 17:44:26.764 [129098675604280] WARN - [Req#1c5] SLOW QUERY: It took 330.000000 ms to retrieve 24 items.
May 22, 2025 17:44:26.811 [129098701179704] WARN - [Req#1cc] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:44:26.811 [129098701179704] WARN - [Req#1cc] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.811 [129098701179704] WARN - [Req#1cc] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.821 [129098672663352] ERROR - [Req#1ce] Unknown metadata type: folder
May 22, 2025 17:44:26.821 [129098672663352] WARN - [Req#1ce] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.821 [129098672663352] WARN - [Req#1ce] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.950 [129098727865144] ERROR - [Req#1d2] Unknown metadata type: folder
May 22, 2025 17:44:26.951 [129098727865144] WARN - [Req#1d2] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:26.951 [129098727865144] WARN - [Req#1d2] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:27.163 [129098713058104] ERROR - [Req#1d7] Unknown metadata type: folder
May 22, 2025 17:44:27.164 [129098713058104] WARN - [Req#1d7] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:27.164 [129098713058104] WARN - [Req#1d7] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:27.360 [129098675604280] WARN - [Req#1d8] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:44:27.360 [129098675604280] WARN - [Req#1d8] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:27.360 [129098675604280] WARN - [Req#1d8] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.498 [129098727865144] ERROR - [Req#1fa] Unknown metadata type: folder
May 22, 2025 17:44:30.498 [129098672663352] WARN - [Req#1f9] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:44:30.498 [129098672663352] WARN - [Req#1f9] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.498 [129098672663352] WARN - [Req#1f9] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.498 [129098727865144] WARN - [Req#1fa] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.498 [129098727865144] WARN - [Req#1fa] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.515 [129098703633208] ERROR - [Req#203] Unknown metadata type: folder
May 22, 2025 17:44:30.516 [129098677713720] ERROR - [Req#1f6] Unknown metadata type: folder
May 22, 2025 17:44:30.516 [129098745322296] ERROR - [Req#204] Unknown metadata type: folder
May 22, 2025 17:44:30.516 [129098703633208] WARN - [Req#203] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.517 [129098703633208] WARN - [Req#203] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.517 [129098675604280] ERROR - [Req#202] Unknown metadata type: folder
May 22, 2025 17:44:30.517 [129098745322296] WARN - [Req#204] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.517 [129098745322296] WARN - [Req#204] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.517 [129098677713720] WARN - [Req#1f6] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.517 [129098677713720] WARN - [Req#1f6] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.518 [129098675604280] WARN - [Req#202] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.518 [129098675604280] WARN - [Req#202] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.557 [129098681932600] WARN - [Req#20a] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:44:30.557 [129098681932600] WARN - [Req#20a] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.557 [129098681932600] WARN - [Req#20a] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.675 [129098725755704] ERROR - [Req#22c] Unknown metadata type: folder
May 22, 2025 17:44:30.675 [129098725755704] WARN - [Req#22c] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.675 [129098725755704] WARN - [Req#22c] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.678 [129098677713720] ERROR - [Req#22e] Unknown metadata type: folder
May 22, 2025 17:44:30.678 [129098677713720] WARN - [Req#22e] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.678 [129098677713720] WARN - [Req#22e] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.695 [129098679823160] WARN - [Req#232] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:44:30.695 [129098679823160] WARN - [Req#232] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:30.695 [129098679823160] WARN - [Req#232] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:31.042 [129098745322296] ERROR - [Req#29c] Unknown metadata type: folder
May 22, 2025 17:44:31.042 [129098745322296] WARN - [Req#29c] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:31.042 [129098745322296] WARN - [Req#29c] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:31.045 [129098727865144] ERROR - [Req#29b] Unknown metadata type: folder
May 22, 2025 17:44:31.045 [129098727865144] WARN - [Req#29b] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:31.045 [129098727865144] WARN - [Req#29b] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:31.275 [129098713058104] WARN - [Req#29e] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:44:31.275 [129098713058104] WARN - [Req#29e] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:44:31.275 [129098713058104] WARN - [Req#29e] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:44:37.181 [129098708060984] ERROR - Couldn't find the file to stream: /usr/lib/plexmediaserver/Resources/Plug-ins-d301f511a/WebClient.bundle/Contents/Resources/js/chunk-3582-82a1e3f87e8650d19943-plex-4.146.0-a95db1b.js
May 22, 2025 17:44:37.182 [129098672663352] ERROR - Couldn't find the file to stream: /usr/lib/plexmediaserver/Resources/Plug-ins-d301f511a/WebClient.bundle/Contents/Resources/js/chunk-9926-06d554c9b56b5225a81b-plex-4.146.0-a95db1b.js
May 22, 2025 17:44:37.182 [129098701179704] ERROR - Couldn't find the file to stream: /usr/lib/plexmediaserver/Resources/Plug-ins-d301f511a/WebClient.bundle/Contents/Resources/js/chunk-1439-099ba09bc09e7fa48ced-plex-4.146.0-a95db1b.js
May 22, 2025 17:44:37.183 [129098725755704] ERROR - Couldn't find the file to stream: /usr/lib/plexmediaserver/Resources/Plug-ins-d301f511a/WebClient.bundle/Contents/Resources/chunk-1439-099ba09bc09e7fa48ced-plex-4.146.0-a95db1b.css
May 22, 2025 17:44:47.641 [129098713058104] INFO - Request: [10.27.2.13:56446 (WAN)] OPTIONS /:/prefs (47 live) #307 TLS GZIP Signed-in Token ()
May 22, 2025 17:44:47.642 [129098813745976] INFO - Completed: [10.27.2.13:56446] 200 OPTIONS /:/prefs (47 live) #307 TLS GZIP 0ms 389 bytes (pipelined: 21)
May 22, 2025 17:45:11.439 [129098679823160] INFO - Request: [10.27.2.13:56725 (WAN)] OPTIONS /:/prefs?ButlerUpdateChannel=0 (7 live) #38c TLS GZIP Signed-in Token ()
May 22, 2025 17:45:11.439 [129098813745976] INFO - Completed: [10.27.2.13:56725] 200 OPTIONS /:/prefs?ButlerUpdateChannel=0 (7 live) #38c TLS GZIP 0ms 389 bytes (pipelined: 1)
May 22, 2025 17:45:11.448 [129098679823160] INFO - Request: [10.27.2.13:56725 (WAN)] PUT /:/prefs?ButlerUpdateChannel=0 (7 live) #394 TLS GZIP Signed-in Token (janusng) (Chrome)
May 22, 2025 17:45:11.451 [129098811636536] INFO - Completed: [10.27.2.13:56725] 200 PUT /:/prefs?ButlerUpdateChannel=0 (7 live) #394 TLS GZIP 3ms 333 bytes (pipelined: 2)
May 22, 2025 17:45:22.292 [129098708060984] ERROR - [Req#419] Unknown metadata type: folder
May 22, 2025 17:45:22.292 [129098708060984] WARN - [Req#419] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.292 [129098708060984] WARN - [Req#419] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.337 [129098679823160] ERROR - [Req#41f] Unknown metadata type: folder
May 22, 2025 17:45:22.338 [129098679823160] WARN - [Req#41f] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.338 [129098679823160] WARN - [Req#41f] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.382 [129098710170424] WARN - [Req#421] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:45:22.382 [129098710170424] WARN - [Req#421] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.382 [129098710170424] WARN - [Req#421] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.384 [129098713058104] WARN - [Req#41e] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:45:22.384 [129098713058104] WARN - [Req#41e] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.384 [129098713058104] WARN - [Req#41e] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.384 [129098703637304] ERROR - [Req#420] Unknown metadata type: folder
May 22, 2025 17:45:22.385 [129098708060984] ERROR - [Req#418] Unknown metadata type: folder
May 22, 2025 17:45:22.385 [129098703637304] WARN - [Req#420] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.385 [129098794007352] ERROR - [Req#416] Unknown metadata type: folder
May 22, 2025 17:45:22.385 [129098703637304] WARN - [Req#420] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.386 [129098708060984] WARN - [Req#418] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.386 [129098796116792] ERROR - [Req#417] Unknown metadata type: folder
May 22, 2025 17:45:22.386 [129098708060984] WARN - [Req#418] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.386 [129098794007352] WARN - [Req#416] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.386 [129098794007352] WARN - [Req#416] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.387 [129098796116792] WARN - [Req#417] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.387 [129098796116792] WARN - [Req#417] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.432 [129098703637304] WARN - [Req#420] SLOW QUERY: It took 220.000000 ms to retrieve 24 items.
May 22, 2025 17:45:22.433 [129098708060984] WARN - [Req#418] SLOW QUERY: It took 220.000000 ms to retrieve 24 items.
May 22, 2025 17:45:22.468 [129098708060984] ERROR - [Req#426] Unknown metadata type: folder
May 22, 2025 17:45:22.468 [129098708060984] WARN - [Req#426] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.468 [129098708060984] WARN - [Req#426] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.476 [129098679823160] WARN - [Req#428] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:45:22.476 [129098679823160] WARN - [Req#428] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.476 [129098679823160] WARN - [Req#428] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.741 [129098794007352] ERROR - [Req#42c] Unknown metadata type: folder
May 22, 2025 17:45:22.741 [129098794007352] WARN - [Req#42c] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.741 [129098794007352] WARN - [Req#42c] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.846 [129098796116792] ERROR - [Req#430] Unknown metadata type: folder
May 22, 2025 17:45:22.846 [129098796116792] WARN - [Req#430] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:22.846 [129098796116792] WARN - [Req#430] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:23.618 [129098713058104] WARN - [Req#431] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:45:23.618 [129098713058104] WARN - [Req#431] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:23.618 [129098713058104] WARN - [Req#431] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.888 [129098703637304] ERROR - [Req#44f] Unknown metadata type: folder
May 22, 2025 17:45:24.888 [129098703637304] WARN - [Req#44f] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.888 [129098703637304] WARN - [Req#44f] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.931 [129098710170424] ERROR - [Req#458] Unknown metadata type: folder
May 22, 2025 17:45:24.931 [129098710170424] WARN - [Req#458] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.931 [129098710170424] WARN - [Req#458] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.960 [129098679823160] WARN - [Req#46f] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:45:24.960 [129098679823160] WARN - [Req#46f] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.960 [129098679823160] WARN - [Req#46f] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.966 [129098710170424] ERROR - [Req#46e] Unknown metadata type: folder
May 22, 2025 17:45:24.967 [129098708060984] ERROR - [Req#46d] Unknown metadata type: folder
May 22, 2025 17:45:24.967 [129098710170424] WARN - [Req#46e] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.967 [129098710170424] WARN - [Req#46e] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.967 [129098703637304] ERROR - [Req#470] Unknown metadata type: folder
May 22, 2025 17:45:24.967 [129098708060984] WARN - [Req#46d] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.967 [129098708060984] WARN - [Req#46d] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.968 [129098703637304] WARN - [Req#470] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.968 [129098703637304] WARN - [Req#470] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.972 [129098713058104] ERROR - [Req#471] Unknown metadata type: folder
May 22, 2025 17:45:24.973 [129098713058104] WARN - [Req#471] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.973 [129098713058104] WARN - [Req#471] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.974 [129098794007352] WARN - [Req#472] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:45:24.974 [129098794007352] WARN - [Req#472] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:24.974 [129098794007352] WARN - [Req#472] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:25.013 [129098708060984] WARN - [Req#46d] SLOW QUERY: It took 230.000000 ms to retrieve 24 items.
May 22, 2025 17:45:25.014 [129098713058104] WARN - [Req#471] SLOW QUERY: It took 210.000000 ms to retrieve 24 items.
May 22, 2025 17:45:25.038 [129098796116792] ERROR - [Req#478] Unknown metadata type: folder
May 22, 2025 17:45:25.038 [129098796116792] WARN - [Req#478] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:25.038 [129098796116792] WARN - [Req#478] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:25.057 [129098708060984] WARN - [Req#47d] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:45:25.057 [129098708060984] WARN - [Req#47d] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:25.057 [129098708060984] WARN - [Req#47d] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:25.317 [129098679823160] ERROR - [Req#4f5] Unknown metadata type: folder
May 22, 2025 17:45:25.317 [129098679823160] WARN - [Req#4f5] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:25.317 [129098679823160] WARN - [Req#4f5] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:25.394 [129098794007352] ERROR - [Req#4f9] Unknown metadata type: folder
May 22, 2025 17:45:25.394 [129098794007352] WARN - [Req#4f9] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:25.394 [129098794007352] WARN - [Req#4f9] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:45:25.577 [129098703637304] WARN - [Req#4fb] QueryParser: Invalid field 'sectionID' found, ignoring.
May 22, 2025 17:45:25.577 [129098703637304] WARN - [Req#4fb] QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
May 22, 2025 17:45:25.577 [129098703637304] WARN - [Req#4fb] QueryParser: Invalid field 'pinnedContentDirectoryID' found, ignoring.
May 22, 2025 17:49:11.068 [129098821737272] WARN - [Database optimization/com.plexapp.plugins.library.db/DatabaseFixups] Held transaction for too long (/home/runner/_work/plex-media-server/plex-media-server/Library/DatabaseFixups.cpp:234): 0.200000 seconds
May 22, 2025 17:49:11.246 [129098821737272] WARN - [Database optimization/com.plexapp.plugins.library.db/DatabaseFixups] Held transaction for too long (/home/runner/_work/plex-media-server/plex-media-server/Library/DatabaseFixups.cpp:402): 0.110000 seconds
May 22, 2025 17:49:12.991 [129098821737272] WARN - [Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (/home/runner/_work/plex-media-server/plex-media-server/Library/FullTextSearch.cpp:58): 1.700000 seconds
May 22, 2025 17:49:14.189 [129098821737272] WARN - [Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (/home/runner/_work/plex-media-server/plex-media-server/Library/FullTextSearch.cpp:71): 0.930000 seconds
May 22, 2025 17:49:16.634 [129098821737272] WARN - [Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (/home/runner/_work/plex-media-server/plex-media-server/Library/FullTextSearch.cpp:81): 2.400000 seconds
May 22, 2025 17:49:19.926 [129098821737272] WARN - [Database optimization/com.plexapp.plugins.library.db] Held transaction for too long (/home/runner/_work/plex-media-server/plex-media-server/Library/FullTextSearch.cpp:94): 3.060000 seconds
May 22, 2025 18:14:20.028 [129098824313656] WARN - JobManager: Could not find job for handle 707
May 22, 2025 18:44:23.196 [129098578606904] WARN - NAT: PMP, got an error: Not Supported by gateway.
May 22, 2025 19:44:23.201 [129098411109176] WARN - NAT: PMP, got an error: Not Supported by gateway.
May 22, 2025 20:43:27.578 [129098811636536] ERROR - WebSocket: closing connection due to fragmentation
May 22, 2025 20:43:27.579 [129098813745976] ERROR - WebSocket: closing connection due to fragmentation
May 22, 2025 20:43:27.579 [129098813745976] WARN - WebSocket: Ignoring message since we're closing the connection
May 22, 2025 20:54:59.630 [129098732084024] ERROR - Network Service: Error in advertiser handle read: 125 (Operation canceled) socket=79
May 22, 2025 20:54:59.642 [129098824313656] WARN - JobManager: Could not find job for handle 614
May 22, 2025 20:54:59.644 [129098824313656] WARN - JobManager: Could not find job for handle 681
May 22, 2025 20:54:59.645 [129098824313656] WARN - JobManager: Could not find job for handle 512
May 22, 2025 20:54:59.647 [129098824313656] WARN - JobManager: Could not find job for handle 365
May 22, 2025 20:54:59.649 [129098824313656] WARN - JobManager: Could not find job for handle 596
May 22, 2025 20:54:59.651 [129098824313656] WARN - JobManager: Could not find job for handle 438
May 22, 2025 20:54:59.730 [129098732084024] INFO - Network Service: Abandoning advertise socket, it was closed.
