Plex Server Registration Issue
Server Version#: 1.43.1.10903-e5521bd8c
Player Version#: 4.160.0
Hi there,
I am experiencing a recurring issue where a Windows Plex Media Server successfully claims to my Plex account, appears normally for a while, and then disappears from the account’s server list.
Environment
Plex Media Server:
  • Windows 11
  • PMS version: 1.43.4.10903-e5521bd8c
  • Server name: Gator’s NAS
  • Machine identifier: 172b39e2f46c3984760c431319f068967d23a978
  • LAN address: 192.168.1.209
  • Plex port: 32400
There is also a second Plex Media Server on the same Plex account named “Tillie.” Tillie continues to appear normally when Gator disappears.
What happens
Gator was successfully reclaimed and initially appeared normally in Plex alongside Tillie.
Local /identity immediately after claiming showed:
claimed = 1
machineIdentifier = 172b39e2f46c3984760c431319f068967d23a978
version = 1.43.4.10903-e5521bd8c
Later, Gator disappeared again from Plex’s server list.
The server itself did NOT go offline.
From another PC on the LAN:
  • Ping to 192.168.1.209 succeeds with 0% loss.
  • TCP connection to 192.168.1.209:32400 succeeds.
  • Plex Web can be opened directly at the server’s LAN address.
On Gator itself, /identity still reports:
claimed = 1
The machine identifier is also unchanged.
Account token is valid
Using the current PlexOnlineToken stored by PMS, I tested:
https://plex.tv/api/resources
The request returns:
HTTP Status: 200
So the account token itself is accepted by Plex.
However, querying the returned Plex resources shows only my other server:
owned: 1
presence: 1
Gator is completely absent from the Plex resource list.
Server-specific Plex endpoint returns 403
Using the same current token against:
https://servers.plex.tv/api/v2/server/access_tokens
returns:
HTTP Status: 403
Plex Media Server itself is seeing the same response.
Relevant PMS log entries include repeated instances of:
HTTP/2.0 403 response from GET https://servers.plex.tv/api/v2/server/access_tokens
MyPlex: Error 403 requesting XML from:
MyPlex: Couldn’t get list of access tokens from myPlex.
There are also repeated 403 responses for:
https://servers.plex.tv/api/v2/server/users/services
Later, PMS logs:
MyPlex: mapping state set to ‘Mapped - Not Published’.
MyPlex: Last published value didn’t change, we’re done.
Remote Access
While Gator is missing from the Plex account’s resource list, Gator’s Remote Access page reports:
“Fully accessible outside your network”
So the server is still running, reachable, claimed, and reports successful Remote Access.
Previous claim/authentication cleanup
Before the current claim, the old PlexOnlineToken had become invalid and returned HTTP 401.
I backed up the Plex registry settings and removed only:
  • PlexOnlineHome
  • PlexOnlineMail
  • PlexOnlineToken
  • PlexOnlineUsername
I then restarted PMS and confirmed:
claimed = 0
The machine identifier remained unchanged.
I used the normal Plex claim/sign-in process to reclaim the server. Afterward:
claimed = 1
The machine identifier was still unchanged, and the newly issued PlexOnlineToken successfully returned HTTP 200 from the general Plex API.
Gator initially appeared normally in Plex after this reclaim.
It subsequently disappeared again.
Current reproducible state
At present:
  • PMS is running normally.
  • Gator is reachable over the LAN.
  • TCP port 32400 is reachable.
  • /identity reports claimed=1.
  • Machine identifier has not changed.
  • The current Plex account token returns HTTP 200 from the general Plex API.
  • Remote Access reports Fully Accessible.
  • /api/resources contains Tillie but not Gator.
  • /api/v2/server/access_tokens returns HTTP 403.
  • PMS logs the same server access-token 403 errors.
  • PMS reports “Mapped - Not Published.”
I have not reinstalled PMS or deleted/reset the Plex database. I have also avoided repeatedly reclaiming the server so that the failed state remains available for diagnosis.
Is there a Plex backend/server-resource issue that could cause a successfully claimed server’s machine identifier to lose its server registration or server-specific authorization while its Plex account token remains valid?
I can provide sanitized Plex Media Server logs covering the successful claim through the subsequent 403 errors and disappearance if needed.
Thanks in advance
  • did you ever “clone” the server’s identity (i.e. its data in the Windows registry) to a second server installation?
  • did you configure “Manually specify public port” in the Remote Access settings for more than one server installation in your local network to the very same external port number?
Nope, I never cloned the server identity/Windows registry from one Plex server installation to the other. The two servers have different machine identifiers.
However, your second question may have found something important. I discovered that I had two DD-WRT port-forwarding rules using the same external TCP port 32400:
Gator’s NAS: external 32400 → 192.168.1.209:32400
Tillie: external 32400 → 192.168.1.98:32400
UPnP is disabled on the router.
I corrected this yesterday. Gator now uses external port 32400, and Tillie uses external port 32401 → internal 32400. I also enabled “Manually specify public port” on Tillie and set it to 32401.
Plex is now advertising the two servers correctly, and both currently show as Nearby. I’m leaving the configuration alone for now to see whether Gator remains available over time, since the original problem was that it would disappear again later.
You can’t use the same external port for both servers. You need to change at least one of them.
