I checked the plex logs (Plex Media Server.log) today and found the following:
Feb 15, 2022 02:11:21.543 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.mozilla/firefox": boost::filesystem::status: Permission denied: "/root/.mozilla/firefox"
Feb 15, 2022 02:11:24.640 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.config/opera/databases/chrome-extension_hnjalnkldgigidggphhmacmimbdlafdo_0": boost::filesystem::status: Permission denied: "/root/.config/opera/databases/chrome-extension_hnjalnkldgigidggphhmacmimbdlafdo_0"
Feb 15, 2022 02:11:27.737 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.config/google-chrome": boost::filesystem::status: Permission denied: "/root/.config/google-chrome"
Feb 15, 2022 02:11:30.833 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.config/BraveSoftware/Brave-Browser": boost::filesystem::status: Permission denied: "/root/.config/BraveSoftware/Brave-Browser"
Feb 15, 2022 02:11:33.928 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.bitcoin": boost::filesystem::status: Permission denied: "/root/.bitcoin"
Feb 15, 2022 02:11:37.024 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.dogecoin": boost::filesystem::status: Permission denied: "/root/.dogecoin"
Feb 15, 2022 02:11:40.120 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.litecoin": boost::filesystem::status: Permission denied: "/root/.litecoin"
Feb 15, 2022 02:11:43.217 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.dashcore": boost::filesystem::status: Permission denied: "/root/.dashcore"
Feb 15, 2022 02:11:46.311 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.electrum/wallets": boost::filesystem::status: Permission denied: "/root/.electrum/wallets"
Feb 15, 2022 02:11:49.421 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.walletwasabi/client/wallets": boost::filesystem::status: Permission denied: "/root/.walletwasabi/client/wallets"
Feb 15, 2022 02:11:52.520 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.local/share/Daedalus/mainnet/wallets": boost::filesystem::status: Permission denied: "/root/.local/share/Daedalus/mainnet/wallets"
Feb 15, 2022 02:11:55.614 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.local/share/Coinomi/wallets": boost::filesystem::status: Permission denied: "/root/.local/share/Coinomi/wallets"
Feb 15, 2022 02:11:58.716 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.ethereum/keystore": boost::filesystem::status: Permission denied: "/root/.ethereum/keystore"
Feb 15, 2022 02:12:01.811 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.config/Jaxx/Local Storage": boost::filesystem::status: Permission denied: "/root/.config/Jaxx/Local Storage"
Feb 15, 2022 02:12:04.905 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.config/com.liberty.jaxx/IndexedDB/file__0.indexeddb.leveldb": boost::filesystem::status: Permission denied: "/root/.config/com.liberty.jaxx/IndexedDB/file__0.indexeddb.leveldb"
Feb 15, 2022 02:12:07.999 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/snap/bitpay/current/.bitpay/app/Local Storage/leveldb": boost::filesystem::status: Permission denied: "/root/snap/bitpay/current/.bitpay/app/Local Storage/leveldb"
Feb 15, 2022 02:12:11.093 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.config/atomic/Local Storage/leveldb": boost::filesystem::status: Permission denied: "/root/.config/atomic/Local Storage/leveldb"
Feb 15, 2022 02:12:14.200 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.config/Exodus/exodus.wallet": boost::filesystem::status: Permission denied: "/root/.config/Exodus/exodus.wallet"
Feb 15, 2022 02:12:17.300 [0x7f200a167b38] ERROR - Couldn't check for the existence of file "/root/.electron-cash/wallets": boost::filesystem::status: Permission denied: "/root/.electron-cash/wallets"
Why tries plex server access to wallet files???
I found this logs for all users on my system!
Looks like you have added /root as part of your library. Under your server settings go to manage → libaries and then edit your library. From there go to the add folders tab and remove the folders which should not be scanned and add only the ones you have media in. Example below …
Very strange. Just checked my logs and I don’t have any of that. Would you be willing to upload a copy of your server logs so we can take a peek and see what might be happening ?
Understand your reluctance to upload logs but really that snipit tells very little. Lets see if a plex member of staff or ninja will jump on this thread and you can DM your full logs.
However, same errors but this time with /home/ also. Can you provide a screenshot of the add folders from your libraries as I’d like to see what you actually have in there.
Not sure it does – at least I’ve never seen doing it.
In addition to dokuro’s question from above (screenshot from the Add Folder tab of the library config)… what agent are you using for the library in question? Any custom/3rd party agents/scanners?
The log snippet you’ve provided doesn’t provide those details. If it’s an actual scan you should see what library is being scanned – otherwise it might be worth checking all libraries for those information.
If this is happening for all user directories on the system, and /root too, perhaps / has been added to a Library, so everything below it is being scanned.
Or perhaps there is a symlink somewhere within a Library, pointing back up to /.
@martinr92 there is nothing in the server afaik that would search those directories. If you would not mind messaging me your logs then I can pass them along to our server team to check.
You can click on my username/avatar to message them to me
It seems not to be triggered by a library scan. The “Plex Media Scanner.log” contains only one entry, but this is a few hours later (the crazy action happened at 2am).
Feb 15, 2022 05:44:18.414 [0x7f1ba3c28b38] INFO - Plex Media Scanner v1.25.5.5492-12f6b8c83 - Debian GNU/Linux PC x86_64 - build: linux-x86_64 - GMT 01:00
Feb 15, 2022 05:44:18.414 [0x7f1ba3c28b38] INFO - Linux version: 10 (buster), language: en-US
Feb 15, 2022 05:44:18.414 [0x7f1ba3c28b38] INFO - Processor: 16-core Intel(R) Xeon(R) CPU D-1541 @ 2.10GHz
Feb 15, 2022 05:44:18.415 [0x7f1ba3c28b38] INFO - /usr/lib/plexmediaserver/Plex Media Scanner --scan --refresh --section 6 --activity 7adeaaee-6b37-4fcb-a334-9428977d88d2 --directory /home/riedltv/published/NFL Super Bowl/Season 2022
The previously uploaded logs is all I have / all what plex has logged. It seems to access this folders totally out of nowhere.
Instead of posting here screenshots of all libraries, I made some screenshots of the SQlite DB instead (hope it’s ok):
Agents Used (nothing special; no plugins):
his logs indicate it is just looking at folders in his home directory in which he happens to have crypto wallet stuff . Plex isn’t trying to access those specifically.
If I have media in /home/chuck/movies' and '/home/chuck/tv', but mistakenly tell PMS to look in /home/chuck (incomplete path), standard Linuxreaddir()will see all thedot` files in my home directory as well as any other subdirectories in /home/chuck.
To be once more clear:
Those folders DO NOT exist.
I don’t have any crypto / wallet things installed on my server.
So it can’t be a “configuration issue”.
Also the “readdir()” makes no sense, because this folder do not exist.
This happened only once and is not reproducible.
In my opinion someone / something is using some king of vulnerability of plex (maybe through the web server port).
@BigWheel Can I permanently enable the Debug Logging without any performance impacts?
