Plex Server will not restart using service plexmediaserver restart
Ubuntu 20.04 LTS:
plexmediaserver_1.19.2.2702-776106bc6_amd64:
When I run the command to restart the service, it takes down the plexmediaserver, but does not restart it. I have pasted below the status after I did the restart, and what happens when I try the start as well.
If I restart the ubuntu server, then it comes back up fully. So every time I upgrade the deb package I find myself having to restart my server as a whole.
ckolb@ubuntuintel:/ service plexmediaserver status ● plexmediaserver.service - Plex Media Server Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled) Active: failed (Result: exit-code) since Sat 2020-04-25 12:02:38 EDT; 2min 19s ago Process: 1958651 ExecStartPre=/bin/sh -c /usr/bin/test -d "{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p “{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" (code=exited, status=0/SUCCESS) Process: 1958660 ExecStart=/bin/sh -c export PLEX_MEDIA_SERVER_INFO_VENDOR="(grep ^NAME= /etc/os-release | awk -F= “{print $2}” | tr -d " )”; export PLEX_MEDIA_SERVER_INFO_DEVICE=“PC”; export PLEX_MEDIA_SERVER_INFO_MODEL="$(un>
Main PID: 1958660 (code=exited, status=255/EXCEPTION)
Apr 25 12:02:33 ubuntuintel systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
Apr 25 12:02:38 ubuntuintel systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 2.
Apr 25 12:02:38 ubuntuintel systemd[1]: Stopped Plex Media Server.
Apr 25 12:02:38 ubuntuintel systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Apr 25 12:02:38 ubuntuintel systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
Apr 25 12:02:38 ubuntuintel systemd[1]: Failed to start Plex Media Server.
ckolb@ubuntuintel:/ service plexmediaserver start ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units === Authentication is required to start 'plexmediaserver.service'. Authenticating as: Christian Kolb (ckolb) Password: ==== AUTHENTICATION COMPLETE === ckolb@ubuntuintel:/ service plexmediaserver status
Active: failed (Result: exit-code) since Sat 2020-04-25 12:05:43 EDT; 12s ago
Process: 1959022 ExecStartPre=/bin/sh -c /usr/bin/test -d “{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” (code=exited, status=0/SUCCESS)
Process: 1959033 ExecStart=/bin/sh -c export PLEX_MEDIA_SERVER_INFO_VENDOR="(grep ^NAME= /etc/os-release | awk -F= "{print \$2}" | tr -d \" )"; export PLEX_MEDIA_SERVER_INFO_DEVICE="PC"; export PLEX_MEDIA_SERVER_INFO_MODEL="(un>
Main PID: 1959033 (code=exited, status=255/EXCEPTION)
Apr 25 12:05:43 ubuntuintel systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.
Apr 25 12:05:43 ubuntuintel systemd[1]: Stopped Plex Media Server.
Apr 25 12:05:43 ubuntuintel systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Apr 25 12:05:43 ubuntuintel systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
Apr 25 12:05:43 ubuntuintel systemd[1]: Failed to start Plex Media Server.
Plex Media Server Logs_2020-04-25_12-16-13.zip (2.3 MB)
Logs from the server just after the latest upgrade was installed and my attempt to restart and then start as well and then finally having to restart the ubuntu server itself.
From the log files, I believe that his is probably the issue:
Apr 25, 2020 12:02:27.864 [0x7faf9f94e080] ERROR - HttpServer: Error binding acceptor: Address already in use
Apr 25, 2020 12:02:27.864 [0x7faf9f94e080] ERROR - HttpServer: Error opening acceptor on IPv6, falling back to IPv4: Address already in use
Apr 25, 2020 12:02:27.864 [0x7faf9f94e080] ERROR - Error: Unable to set up server: listen: Address already in use (N5boost10wrapexceptINS_6system12system_errorEEE)
When I reboot, the server must start before another process is running. Though I do not know what that process is. Especially since I do not use anything else on port 32400 that I am aware.
If I now do a service plexmediaservice restart, everything restarts fine. This happens after I do a update of the server that this happens.
To see what’s listening on that port
netstat -la | grep 32400
I’d be half tempted to check what systemctl says and what your .service looks like.
Next time I do a update of the service, I was planning on doing a netstat to see what process had open the port. I could easily kill that process. Also, then look at either changing the port for that, or remove what ever process was using it. It may also be that the plexmedia server is not letting go of the ports fully as well.
I am still not proficient with Linux, and in fact using my plex server as w way to get better antiquated with linux. So i did do a few things with systemctl like systemctl list-unit-files, and ```
systemctl list-units to see if that brought anything up that may be of help, but did not see anything of use there.
Apr 25, 2020 12:09:28.371 [0x7f4b11ffb700] DEBUG - [Notify] Now watching "/movies/Music/Soul Coughing/Irresistible Bliss"
Apr 25, 2020 12:09:28.372 [0x7f4b11ffb700] DEBUG - [Notify] Now watching "/movies/Music/Soul Coughing/Ruby Vroom"
Apr 25, 2020 12:09:28.373 [0x7f4b11ffb700] DEBUG - [Notify] Now watching "/movies/Music/Soul II Soul"
Apr 25, 2020 12:09:28.374 [0x7f4b11ffb700] DEBUG - [Notify] Now watching "/movies/Music/Soul II Soul/Club Classics, Vol. 1"
Apr 25, 2020 12:09:28.375 [0x7f4b11ffb700] DEBUG - [Notify] Now watching "/movies/Music/SoulDecision"
Apr 25, 2020 12:09:28.375 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/SoulDecision/Faded (Single)" (28: No space left on device)
Apr 25, 2020 12:09:28.377 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Sound Ideas" (28: No space left on device)
Apr 25, 2020 12:09:28.377 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Sound Ideas/6010" (28: No space left on device)
Apr 25, 2020 12:09:28.378 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Sound Ideas/6058" (28: No space left on device)
Apr 25, 2020 12:09:28.379 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Sound Of Philly and More" (28: No space left on device)
Apr 25, 2020 12:09:28.380 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Sound Of Philly and More/Saturday Morning House Party" (28: No space left on device)
Apr 25, 2020 12:09:28.381 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack" (28: No space left on device)
Apr 25, 2020 12:09:28.386 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Metropolis Sound Track" (28: No space left on device)
Apr 25, 2020 12:09:28.387 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/After The Snow" (28: No space left on device)
Apr 25, 2020 12:09:28.388 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Almost Famous Soundtrack" (28: No space left on device)
Apr 25, 2020 12:09:28.389 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Amadeus Soundtrack" (28: No space left on device)
Apr 25, 2020 12:09:28.390 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Austin Powers" (28: No space left on device)
Apr 25, 2020 12:09:28.391 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Batman Forever" (28: No space left on device)
Apr 25, 2020 12:09:28.392 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/BO" (28: No space left on device)
Apr 25, 2020 12:09:28.393 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Breakfast Club Soundtrack, The" (28: No space left on device)
Apr 25, 2020 12:09:28.395 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Bridget Jones's Diary" (28: No space left on device)
Apr 25, 2020 12:09:28.396 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Cant Hardly Wait" (28: No space left on device)
Apr 25, 2020 12:09:28.397 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Chocolat - Music from the Mira" (28: No space left on device)
Apr 25, 2020 12:09:28.398 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Chocolat - Soundtrack" (28: No space left on device)
Apr 25, 2020 12:09:28.399 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Crooked Rain, Crooked Rain" (28: No space left on device)
Apr 25, 2020 12:09:28.400 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Deadman On Campus Soundtrack" (28: No space left on device)
Apr 25, 2020 12:09:28.401 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Don't You (Forget About Me)" (28: No space left on device)
Apr 25, 2020 12:09:28.407 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Gone In 60 Seconds OST" (28: No space left on device)
Apr 25, 2020 12:09:28.418 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Matrix" (28: No space left on device)
Apr 25, 2020 12:09:28.429 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Mother Love Bone Disc 1" (28: No space left on device)
Apr 25, 2020 12:09:28.430 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Music From Baz Luhrmann's Film Moulin Ro" (28: No space left on device)
Apr 25, 2020 12:09:28.443 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Not Another Teen Movie" (28: No space left on device)
Apr 25, 2020 12:09:28.444 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Not Another Teen Movie (OST)" (28: No space left on device)
Apr 25, 2020 12:09:28.445 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/O Brother" (28: No space left on device)
Apr 25, 2020 12:09:28.446 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/O'Brother, where art thou" (28: No space left on device)
Apr 25, 2020 12:09:28.447 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/OLIVER" (28: No space left on device)
Apr 25, 2020 12:09:28.448 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Oliver!" (28: No space left on device)
Apr 25, 2020 12:09:28.449 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/One fine Day soundtrack" (28: No space left on device)
Apr 25, 2020 12:09:28.458 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Pablo Honey" (28: No space left on device)
Apr 25, 2020 12:09:28.459 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Pokemon the first movie" (28: No space left on device)
Apr 25, 2020 12:09:28.459 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Pretty In Pink Soundtrack" (28: No space left on device)
Apr 25, 2020 12:09:28.460 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Prince of Egypt Soundtrack" (28: No space left on device)
Apr 25, 2020 12:09:28.461 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Pulp Fiction Soundtrack" (28: No space left on device)
Apr 25, 2020 12:09:28.462 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Soundtrack/Reality Bites - Soundtrack" (28: No space left on device)
Apr 25, 2020 12:09:28.463 [0x7f4b11ffb700] ERROR - [Notify] Failed to add watch for "/movies/Music/Sound
Ran out of inotify slots. This needs updating first. Let’s get the startup settled.
it came back with 12617 for the directory count. however, I did double the default to 65536 since, as you noticed in the log, it was running out of space. I have since restarted the plex server to accept that. I will keep an eye on the restart after I do the next update and restart of the plex server after the update. See if this fixes the issue. If not, and I see the port issue above durring the restart, I will do a netstat to see if I can see what is running on that port.
Good. We’ll get through this, one small step at a time if need be.
OK, I applied the update just now and the restart was done afterward
Plex did not restart Looking at the netstat It looks like my Unifi webapp is taking that port.
ckolb@ubuntuintel:~/Documents/Scripts$ more Plex_Update.sh
sudo dpkg -i /share/plexmediaserver_update.deb
sudo rm /share/plexmediaserver_update.deb
ckolb@ubuntuintel:~/Documents/Scripts$ ./Plex_Update.sh
[sudo] password for ckolb:
(Reading database … 122260 files and directories currently installed.)
Preparing to unpack …/plexmediaserver_update.deb …
PlexMediaServer install: Pre-installation Validation.
PlexMediaServer install: Pre-installation Validation complete.
Unpacking plexmediaserver (1.19.3.2740-add6f438d) over (1.19.2.2702-776106bc6) . …
Setting up plexmediaserver (1.19.3.2740-add6f438d) …
PlexMediaServer install: PlexMediaServer-1.19.3.2740-add6f438d - Installation st arting.
PlexMediaServer install: Now installing based on:
PlexMediaServer install: Installation Type: Update
PlexMediaServer install: Process Control: systemd
PlexMediaServer install: Plex User: plex
PlexMediaServer install: Plex Group: plex
PlexMediaServer install: Video Group: video
PlexMediaServer install: Metadata Dir: /var/lib/plexmediaserver/Library /Application Support
PlexMediaServer install: Temp Directory: /tmp/ramdisk (set in Preference s.xml)
PlexMediaServer install: Lang Encoding: en_US.UTF-8
PlexMediaServer install: Transcoding HW: Found
PlexMediaServer install: Completing final configuration.
PlexMediaServer install: Starting Plex Media Server.
PlexMediaServer install: PlexMediaServer-1.19.3.2740-add6f438d - Installation su ccessful. Errors: 0, Warnings: 0
Processing triggers for libc-bin (2.31-0ubuntu9) …
Processing triggers for mime-support (3.64ubuntu1) …
Authentication is required to restart ‘plexmediaserver.service’.
Password:
ckolb@ubuntuintel:~/Documents/Scripts$ netstat -al |grep 32400
tcp 0 0 ubuntu_intel:53488 ubuntu_intel:32400 TIME_WAIT
tcp 0 0 ubuntu_intel:53956 ubuntu_intel:32400 TIME_WAIT
tcp 0 0 ubuntu_intel:53300 ubuntu_intel:32400 TIME_WAIT
tcp 0 0 ubuntu_intel:53738 ubuntu_intel:32400 TIME_WAIT
tcp 0 0 ubuntu_intel:53552 ubuntu_intel:32400 TIME_WAIT
tcp 0 0 ubuntu_intel:53862 ubuntu_intel:32400 TIME_WAIT
tcp 0 0 ubuntu_intel:54032 ubuntu_intel:32400 TIME_WAIT
tcp 0 0 ubuntu_intel:53424 ubuntu_intel:32400 TIME_WAIT
tcp6 0 0 [::]:32400 [::]:* LISTEN
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54034 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:53610 TIME_WAIT
tcp6 0 0 unifi:32400 67.21.32.52:19896 TIME_WAIT
tcp6 0 0 unifi:32400 192.168.1.31:1979 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54042 TIME_WAIT
tcp6 0 0 unifi:32400 c-73-151-3-137.hs:59094 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54086 TIME_WAIT
tcp6 0 0 unifi:32400 192.168.1.31:19815 TIME_WAIT
tcp6 0 0 unifi:32400 192.168.1.31:19860 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54018 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54056 TIME_WAIT
tcp6 0 0 unifi:32400 c-73-151-3-137.hs:59386 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54078 TIME_WAIT
tcp6 0 0 unifi:32400 67.21.32.52:19835 TIME_WAIT
tcp6 0 0 unifi:32400 192.168.1.31:19827 TIME_WAIT
tcp6 0 0 unifi:32400 192.168.1.31:19819 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54062 TIME_WAIT
tcp6 0 0 unifi:32400 192.168.1.31:19848 TIME_WAIT
tcp6 0 0 unifi:32400 67.21.32.52:19814 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:53668 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54090 TIME_WAIT
tcp6 0 0 unifi:32400 67.21.32.52:19885 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54046 TIME_WAIT
tcp6 0 0 unifi:32400 67.21.32.52:19847 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54016 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54082 TIME_WAIT
tcp6 0 0 unifi:32400 192.168.1.31:19886 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54060 TIME_WAIT
tcp6 0 0 unifi:32400 192.168.1.31:19829 TIME_WAIT
tcp6 0 0 unifi:32400 192.168.1.31:19813 ESTABLISHED
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54014 TIME_WAIT
tcp6 0 0 unifi:32400 192.168.1.31:19897 TIME_WAIT
tcp6 0 0 unifi:32400 192.168.1.31:6184 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54080 TIME_WAIT
tcp6 0 0 unifi:32400 192.168.1.31:19823 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54020 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54088 TIME_WAIT
tcp6 0 0 unifi:32400 192.168.1.31:19836 TIME_WAIT
tcp6 0 0 unifi:32400 67.21.32.52:19859 TIME_WAIT
tcp6 0 0 127.0.0.1:32400 127.0.0.1:54036 TIME_WAIT
tcp6 0 0 unifi:32400 67.21.32.52:19818 TIME_WAIT
However, Unifi is running on port 8443
https://192.168.1.150:8443/manage/site/default/dashboard is what I go to for that web page.
This is very strange.
do this:
systemctl disable plexmediaserver
shutdown -r now
-- after restart--
netstat -an | grep 324
When it comes back up, Look for anything on ports 324xx
ckolb@ubuntuintel:/etc/init.d$ systemctl disable plexmediaserver
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files ===
Authentication is required to manage system service or unit files.
Password:
==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon ===
Authentication is required to reload the systemd state.
Password:
ckolb@ubuntuintel:/etc/init.d$ shutdown -r now
Failed to set wall message, ignoring: Interactive authentication required.
Failed to reboot system via logind: Interactive authentication required.
Failed to open initctl fifo: Permission denied
Failed to talk to init daemon.
ckolb@ubuntuintel:/etc/init.d$ netstat -an | grep 324
tcp 0 0 127.0.0.1:32401 0.0.0.0:* LISTEN
tcp6 0 0 :::32400 :::* LISTEN
udp 0 0 0.0.0.0:32410 0.0.0.0:*
udp 0 0 0.0.0.0:32412 0.0.0.0:*
udp 0 0 0.0.0.0:32413 0.0.0.0:*
udp 0 0 0.0.0.0:32414 0.0.0.0:*
Need to use SUDO
Doing that now
ckolb@ubuntuintel:~$ netstat -an | grep 324
So, with the server back up after a reboot and Unifi up and running properly and plex has not started, nothing is grabbing the ports Plex uses.
I can restart the Plex server at this time if you want me to, or would you like to look at other things before I start it back up
That tells me PMS is up and listening on its ports as it should be.
Grab a ZIP or tar.gz of the Logs directory (under Plex Media Server directory)
logs.tar (5.7 MB)
The server is trying to start while the port is still open.
There’s another instance (theoretically not possible) or something else on the port.
Apr 30, 2020 14:55:50.030 [0x7fe817620700] INFO - Plex Media Server v1.19.3.2740-add6f438d - Ubuntu PC x86_64 - build: linux-x86_64 debian - GMT -04:00
Apr 30, 2020 14:55:50.030 [0x7fe817620700] INFO - Linux version: 20.04 LTS (Focal Fossa), language: en-US
Apr 30, 2020 14:55:50.030 [0x7fe817620700] INFO - Processor Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz
Apr 30, 2020 14:55:50.030 [0x7fe817620700] INFO - /usr/lib/plexmediaserver/Plex Media Server
Apr 30, 2020 14:55:50.029 [0x7fe81810b100] DEBUG - BPQ: [Idle] -> [Starting]
Apr 30, 2020 14:55:50.029 [0x7fe81810b100] DEBUG - FeatureManager: Using cached data for features list
Apr 30, 2020 14:55:50.029 [0x7fe81810b100] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.26.0, threadsafe=1
Apr 30, 2020 14:55:50.050 [0x7fe81810b100] DEBUG - Running migrations. (EPG 0)
Apr 30, 2020 14:55:50.134 [0x7fe81810b100] DEBUG - ChangestampAllocator: initialized to 4884708
Apr 30, 2020 14:55:50.134 [0x7fe81810b100] DEBUG - Opening 2 database sessions to library (com.plexapp.plugins.library.blobs), SQLite 3.26.0, threadsafe=1
Apr 30, 2020 14:55:50.137 [0x7fe81810b100] DEBUG - Running migrations. (EPG 0)
Apr 30, 2020 14:55:50.147 [0x7fe81810b100] DEBUG - CERT: Installed certificate with fingerprint 08:80:ad:69:6a:de:41:82:e8:5a:15:67:11:64:bc:d0:33:b3:ec:7d.
Apr 30, 2020 14:55:50.147 [0x7fe81810b100] DEBUG - CERT: Installed new private key.
Apr 30, 2020 14:55:50.147 [0x7fe81810b100] DEBUG - CERT: Subject name is /C=US/ST=California/L=Los Gatos/O=Plex, Inc./CN=*.906c31bb0def47e7b5996271df77923b.plex.direct
Apr 30, 2020 14:55:50.147 [0x7fe81810b100] DEBUG - CERT: OCSP requests for stapling will be made to 'http://ocspx.digicert.com/'.
Apr 30, 2020 14:55:50.147 [0x7fe81810b100] INFO - OCSP: Successfully retrieved response from cache.
Apr 30, 2020 14:55:50.147 [0x7fe81810b100] DEBUG - CERT: Installed intermediate certificate.
Apr 30, 2020 14:55:50.147 [0x7fe81810b100] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Apr 30, 2020 14:55:50.147 [0x7fe81810b100] ERROR - HttpServer: Error binding acceptor: Address already in use
Apr 30, 2020 14:55:50.147 [0x7fe81810b100] ERROR - HttpServer: Error opening acceptor on IPv6, falling back to IPv4: Address already in use
Apr 30, 2020 14:55:50.148 [0x7fe81810b100] ERROR - Error: Unable to set up server: listen: Address already in use (N5boost10wrapexceptINS_6system12system_errorEEE)
Restart please.
I did a enable on the plexmedia server and it asked for my password, put that in and then did a service plexmediaserver start and that failed again.
I have now rebooted the server to bring things back up once again.
I have attached the logs from plex as well just after the restart of plex after the restart of the server. I hope that between the first set of logs I tared up before the reboot, and thes you may see something.
Also, very much appreciate your help with this.
Plex Media Server Logs_2020-04-30_19-48-41.zip (1.9 MB)
According to the logs,
  1. PMS started
  2. The network bounced a few times before stabilizing – not happy about that but “ok”.
  3. I see the playback request but never see the playback start.
  4. I do see the poster images being prepared for display in the client.
  5. And then I see this Certificate issue. Maybe a bad network read , or a bad cert. Uncertain.
Apr 30, 2020 19:48:29.691 [0x7f6ddaffd700] DEBUG - Request: [192.168.1.31:42915 (Subnet)] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (9 live) TLS GZIP Signed-in Token (Scubatampa)
Apr 30, 2020 19:48:29.691 [0x7f6ddaffd700] DEBUG - Content-Length is -1 (of total: -1).
Apr 30, 2020 19:48:36.615 [0x7f6ddbfff700] DEBUG - CERT: incomplete TLS handshake: sslv3 alert certificate unknown
Apr 30, 2020 19:48:36.622 [0x7f6ddaffd700] DEBUG - Request: [192.168.1.31:43017 (Subnet)] GET /web/common/img/backgrounds/preset-dark2.6d2c8336496f761f38de8558a2b9709b.png (5 live) TLS GZIP Signed-in
Apr 30, 2020 19:48:36.622 [0x7f6ddaffd700] DEBUG - Final path: "/usr/lib/plexmediaserver/Resources/Plug-ins-add6f438d/WebClient.bundle/Contents/Resources/common/img/backgrounds/preset-dark2.6d2c8336496f761f38de8558a2b9709b.png"
Apr 30, 2020 19:48:36.622 [0x7f6ddaffd700] DEBUG - Content-Length of /usr/lib/plexmediaserver/Resources/Plug-ins-add6f438d/WebClient.bundle/Contents/Resources/common/img/backgrounds/preset-dark2.6d2c8336496f761f38de8558a2b9709b.png is 113817 (of total: 113817).
Apr 30, 2020 19:48:36.623 [0x7f6ddbfff700] DEBUG - Completed: [192.168.1.31:43017] 200 GET /web/
Yes, this is after I have restarted. Log 1, 2, and 3 are all from before the reboot, but after the steps you had me take. As you can see in those logs, there is that dang port issue again.
its like it starts up and then the port is taken. I verified before starting that it was like above, not like after I try and start and it fails and then do the netstat and see all the connections to 32400 and some from Unifi.
I have been persuing this on the Unifi site as well, asking them if they have seen this. They have not.
