Server Version#: 1.40.2.8395
Player Version#: Latest
Hi, newbie here. I noticed there are some Plex wrapper apps that uses Vision Pro’s native player, but when the video has bframes, it will play certain frames in the wrong order. This bugs me a lot and developers have not really found a way to resolve it. It’s not a Vision Pro player issue either because when playing that file locally on Vision Pro it does not have an issue. There must be something wrong where Plex passes the option of frame reordering to the Vision Pro player, or it’s not receiving the correct enable option.
I wonder if there is a setting in plex to disable/enable bframes or Frame Reordering? Either through settings in UI, or modify the xml ourselves. Thanks a lot!
