Plex transcoder.exe crashes
Server Version#:1.43.0.10346
Random Plex Server crashes. Windows 11 produces the following:
Description
Faulting Application Path: C:\Program Files\Plex\Plex Media Server\Plex Transcoder.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: Plex Transcoder.exe
Application Version: 0.0.0.0
Application Timestamp: 6919e00b
Fault Module Name: avformat-60.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 6919dff7
Exception Code: 40000015
Exception Offset: 000000000006665f
OS Version: 10.0.26200.2.0.0.256.48
Locale ID: 1033
Additional Information 1: 343e
Additional Information 2: 343e4b3d65277db8430d28e06b4a9fd5
Additional Information 3: 32dd
Additional Information 4: 32dd556fe21bf7a18a0969f443765eb7
Please help. Next steps?
The server logs would also be very helpful.
Done.
Thank you.
Plex Media Server Logs_2025-11-26_10-00-16.zip (3.0 MB)
Help. Crashed again.
Anybody???
Might have found something, After no response to this thread I at least setup a script to run in Task Scheduler to restart Plex Media Server every 10 minutes. Looking this AM at the history of that run reveals that Plex Media Server.exe crashed at 2:09 AM, the exact same time I have AOMEI Backupper run nightly a system backup.
I would check the scheduled task time window and avoid having the two conflict.
Thank you for the response.
I didn’t setup the Task Scheduler task until after experiencing repeated nighttime Plex Media Server crashes. (so, the PMS.exe crashes preceded the Task Scheduler work)
Does the latest beta address this issue?
Have installed it now. Was on the prior beta release.
Chris, please follow this thread as I’ll report results. Shouldn’t take long :slight_smile:
Installed current beta, stopped my Task Scheduler script, and hoped. No joy as PMS.exe has again crashed.
Help
It ran all night without error. I moved the maintenance tasks of Plex to late afternoon to see if it crashes then.
