Plex transcoder failing. MKV
Server Version#: Version 1.25.9.5721
Player Version#: Web Version 4.78.4
Hello,I am seeking some insight on a behavior I am seeing from my server. It is relatively new as the server itself has been deployed for months without any issues.
Essentially, I am playing a 720P MKV Video using Brave browser on my Main PC on LAN from my PLEX server. The video buffers nicely for around 5 minutes or so, then at some point stops. If I reload the page, it begins to load just fine again, for about 5-10 more minutes and issue re-appears.
Spec: Ryzen 7 2700, 16GB RAM, 5 TB volume using storage spaces RAID 5Plex Version 1.25.9.5721
CPU usage is around 10% when plex is running, drive usage is under 20%
Video is playing at original quality, no subtitles, MKV file format. Here is the file info
**I managed to find in logs that the plex transcoder is exiting due to error 1073807364 in one of my log files **
Pastebin
I searched for that code within the subreddit and didn’t get results, I am doing the googles but I am not finding Plex specific results yet.
I found one transcoder document from plex . I can confirm this system does NOT have MBAM installed on it, I have disabled windows defender as a troubleshooting step however. It did not work.
I closed plex, deleted my logs, launched a session, played a video and ran into the issue at approx 5:30 in these new more extensive logs
Last update for the night: This same video file played back completely on plex on android 9.0.4.31825 via cellular data.
Does anyone have any experience with this?
Edit:
So.. after some research I found This comment in a thread where essentially they said after a certain update plex on chrome sucks and to either roll back the server or use the actual plex app.
Downloaded and installed plex for windows from the plex website, so far so good, have not had any playback issues. Thats kind of dumb but whatever, I can certainly accept this
