Hey, so I got a slot from ultraseedbox and I installed plex on it.
I have some mkv files that I added to the library but form some reason, it gets stuck on loading when I try to watch them.
I think its a transcode problem but I dont know what and how to fix it.
I connected the slot via SSH and ran the command: “ps -ef | grep plex” and one of the services i got was this(the transcoder service):
/usr/lib/plexmediaserver/Plex Transcoder -codec:0 h264 -codec:1 ac3_eae -eae_prefix:1 2mjrb7hc0xxlpsnrg6f8lp9z_ -ss 209.222 -noaccurate_seek -i /home18/brolix/Plex/Series/The.Magicians.US.S02E01.720p.HDTV.x264-KILLERS.mkv -map 0:0 -codec:0 copy -map 0:1 -codec:1 aac -ar:1 48000 -channel_layout:1 stereo -b:1 217k -f segment -segment_format matroska -segment_format_options live=1 -segment_time 1 -segment_header_filename header -segment_start_number 0 -segment_list http://127.0.0.1:32400/video/:/transcode/session/2mjrb7hc0xxlpsnrg6f8lp9z/seglist -segment_list_type csv -segment_list_size 2147483647 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 chunk-%05d -start_at_zero -copyts -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/2mjrb7hc0xxlpsnrg6f8lp9z/progress
Is it possible the url at the end is the problem?( http://127.0.0.1:32400/video**/:/**transcode )
I tried restarting the PMS few times. One time I got it to play the file but when I closed it and open it up again, it just got stuck…
Maybe its because of the cpu usage? If so, what can I change in the options to make it work?
CPU(s): 48
On-line CPU(s) list: 0-47
Thread(s) per core: 2
Core(s) per socket: 12
Socket(s): 2
NUMA node(s): 2
Vendor ID: GenuineIntel
CPU family: 6
Model: 63
Model name: Intel® Xeon® CPU E5-2676 v3 @ 2.40GHz
my PMS suppose to have access to 3 threads on the cpu.
I also ran the “top” command while loading an episode, the transcoder takes 99%+ CPU.
Also, it says that i’m direct streaming the video & transcoding the audo from AC3 to AAC.
I have 500Mbit/s upload/download so the internet speed it fine.
