Plex Transcoder Issues
Server Version#: 1.43.2.10687
Player Version#: multiple players
I am having an issue with 2 mkv files:
  1. Playback error - Conversion failed. The transcoder exited due to an error.
  2. Playback error - An unknown error occurred (4294967283) Error code: 4294967283
How do I trouble shoot this. . My google searches and AI searches are not giving me anything makes senses or refers to commands not in my unraid container or says to go to a location that is not right for which I fix and get command not found.
Here the logs tell me if you need anythign else or point me int he right direction for troubleshooting
thank you
Plex Media Server.zip (695.5 KB)
I see the errors in your logs but your logs are missing a lot of information that would be helpful to know. Please do the following;
  1. Confirm server DEBUG logging is enabled, VERBOSE logging is disabled.
    SAVE if changes.
  2. Restart PMS
  3. Give it two minutes to start and stabilize
  4. Start a playback which shows the issue
  5. Let it play for 20 seconds
  6. Stop the playback
  7. Download the server logs
  8. Attach the logs so I may see them.
For the problematic files, do they play on something like VLC? Can you provide a sample file of the problematic files?
