I see it. THANK YOU (tired eyes here)
I see it failing the ‘fast seek’ step.
This is where it restarts, changes transcode parameters and seeks back into the file to continue.
Aug 31, 2023 16:44:31.125 [139645733210936] DEBUG - [Req#1a7/Transcode/Req#1a8] We're going to try to auto-select an audio stream for account 1.
Aug 31, 2023 16:44:31.125 [139645733210936] DEBUG - [Req#1a7/Transcode/Req#1a8] Selecting best audio stream for part ID 4196 (language: )
Aug 31, 2023 16:44:31.125 [139645733210936] DEBUG - [Req#1a7/Transcode/Req#1a8] Audio Stream: 26146, Subtitle Stream: -1
Aug 31, 2023 16:44:31.126 [139645733210936] DEBUG - [Req#1a7/Transcode] Found session GUID of fssydvb929ngan63cxzmapij in session start.
Aug 31, 2023 16:44:31.127 [139645733210936] DEBUG - [Req#1a7/Transcode] Cleaning directory for session fssydvb929ngan63cxzmapij ()
Aug 31, 2023 16:44:31.127 [139645733210936] DEBUG - [Req#1a7/Transcode] Starting a transcode session fssydvb929ngan63cxzmapij at offset -1.0 (state=3)
Aug 31, 2023 16:44:31.128 [139645733210936] DEBUG - [Req#1a7/Transcode/JobRunner] In directory: "/tmp/Transcode/Sessions/plex-transcode-fssydvb929ngan63cxzmapij-084de49b-29cf-4515-9c04-2f1b9689716d"
Aug 31, 2023 16:44:31.128 [139645733210936] DEBUG - [Req#1a7/Transcode/JobRunner] Jobs: Starting child process with pid 3307762
Aug 31, 2023 16:44:31.137 [139645694491448] DEBUG - Request: [127.0.0.1:59462 (Loopback)] PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress?status=startup (6 live) #19c Token () (range: bytes=0-)
Aug 31, 2023 16:44:31.137 [139645811747640] DEBUG - Completed: [127.0.0.1:59462] 204 PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress?status=startup (6 live) #19c 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Aug 31, 2023 16:44:31.141 [139645719804728] DEBUG - Request: [127.0.0.1:59462 (Loopback)] PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress?status=startup (6 live) #1ab Token () (range: bytes=0-)
Aug 31, 2023 16:44:31.141 [139645813857080] DEBUG - Completed: [127.0.0.1:59462] 204 PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress?status=startup (6 live) #1ab 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Aug 31, 2023 16:44:31.142 [139645769710392] DEBUG - Request: [127.0.0.1:59462 (Loopback)] PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress?status=opening (6 live) #1ac Token () (range: bytes=0-)
Aug 31, 2023 16:44:31.142 [139645813857080] DEBUG - Completed: [127.0.0.1:59462] 204 PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress?status=opening (6 live) #1ac 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Aug 31, 2023 16:44:31.173 [139645696600888] DEBUG - Request: [127.0.0.1:59462 (Loopback)] PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress?status=opened (6 live) #1ad Token () (range: bytes=0-)
Aug 31, 2023 16:44:31.173 [139645811747640] DEBUG - Completed: [127.0.0.1:59462] 204 PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress?status=opened (6 live) #1ad 0ms 203 bytes (pipelined: 4) (range: bytes=0-)
Aug 31, 2023 16:44:31.174 [139645722352440] DEBUG - Request: [127.0.0.1:59462 (Loopback)] PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress/stream?index=0&id=0&codec=h264&type=video (6 live) #1ae Token () (range: bytes=0-)
Aug 31, 2023 16:44:31.174 [139645811747640] DEBUG - Completed: [127.0.0.1:59462] 200 PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress/stream?index=0&id=0&codec=h264&type=video (6 live) #1ae 0ms 195 bytes (pipelined: 5) (range: bytes=0-)
Aug 31, 2023 16:44:31.174 [139645694491448] DEBUG - Request: [127.0.0.1:59462 (Loopback)] PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress/stream?index=1&id=0&codec=eac3&type=audio (6 live) #1af Token () (range: bytes=0-)
Aug 31, 2023 16:44:31.175 [139645811747640] DEBUG - Completed: [127.0.0.1:59462] 200 PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress/stream?index=1&id=0&codec=eac3&type=audio (6 live) #1af 0ms 195 bytes (pipelined: 6) (range: bytes=0-)
Aug 31, 2023 16:44:31.221 [139645719804728] DEBUG - Request: [127.0.0.1:59462 (Loopback)] PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress/streamDetail?index=0&id=0&codec=h264&type=video&profile=High&width=1920&height=1080&interlaced=0&sar=1:1&level=40&frameRate=23.976&disp_default=1 (6 live) #1b0 Token () (range: bytes=0-)
Aug 31, 2023 16:44:31.222 [139645813857080] DEBUG - Completed: [127.0.0.1:59462] 200 PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress/streamDetail?index=0&id=0&codec=h264&type=video&profile=High&width=1920&height=1080&interlaced=0&sar=1:1&level=40&frameRate=23.976&disp_default=1 (6 live) #1b0 0ms 195 bytes (pipelined: 7) (range: bytes=0-)
Aug 31, 2023 16:44:31.222 [139645769710392] DEBUG - Request: [127.0.0.1:59462 (Loopback)] PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress/streamDetail?index=1&id=0&codec=eac3&type=audio&language=eng&channels=6&layout=5.1%28side%29&sampleRate=48000&disp_default=1 (6 live) #1b1 Token () (range: bytes=0-)
Aug 31, 2023 16:44:31.223 [139645813857080] DEBUG - Completed: [127.0.0.1:59462] 200 PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress/streamDetail?index=1&id=0&codec=eac3&type=audio&language=eng&channels=6&layout=5.1%28side%29&sampleRate=48000&disp_default=1 (6 live) #1b1 0ms 195 bytes (pipelined: 8) (range: bytes=0-)
Aug 31, 2023 16:44:31.223 [139645696600888] DEBUG - Request: [127.0.0.1:59462 (Loopback)] PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress/streamDetail?index=2&id=0&codec=subrip&type=subtitle&language=eng (6 live) #1b2 Token () (range: bytes=0-)
Aug 31, 2023 16:44:31.223 [139645813857080] DEBUG - Completed: [127.0.0.1:59462] 200 PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress/streamDetail?index=2&id=0&codec=subrip&type=subtitle&language=eng (6 live) #1b2 0ms 195 bytes (pipelined: 9) (range: bytes=0-)
Aug 31, 2023 16:44:31.223 [139645722352440] DEBUG - Request: [127.0.0.1:59462 (Loopback)] PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress/streamDetail?index=3&id=0&codec=subrip&type=subtitle&language=eng&disp_hearing_impaired=1 (6 live) #1b3 Token () (range: bytes=0-)
Aug 31, 2023 16:44:31.224 [139645813857080] DEBUG - Completed: [127.0.0.1:59462] 200 PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress/streamDetail?index=3&id=0&codec=subrip&type=subtitle&language=eng&disp_hearing_impaired=1 (6 live) #1b3 0ms 195 bytes (pipelined: 10) (range: bytes=0-)
Aug 31, 2023 16:44:31.226 [139645694491448] DEBUG - Request: [127.0.0.1:59462 (Loopback)] PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress?duration=2342.176000 (6 live) #1b4 Token () (range: bytes=0-)
Aug 31, 2023 16:44:31.226 [139645733210936] DEBUG - [Req#1a7/Transcode] Started session successfully: fssydvb929ngan63cxzmapij
Aug 31, 2023 16:44:31.226 [139645811747640] DEBUG - Completed: [127.0.0.1:59462] 204 PUT /video/:/transcode/session/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d/progress?duration=2342.176000 (6 live) #1b4 0ms 203 bytes (pipelined: 11) (range: bytes=0-)
Aug 31, 2023 16:44:31.227 [139645813857080] DEBUG - Completed: [192.168.1.3:51234] 200 GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F4178&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&maxVideoBitrate=2000&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=fssydvb929ngan63cxzmapij&subtitles=burn&Accept-Language=en (6 live) #1a7 GZIP 112ms 952 bytes (pipelined: 49)
Aug 31, 2023 16:44:31.232 [139645719804728] DEBUG - Request: [192.168.1.3:51234 (Allowed Network (Subnet))] GET /status/sessions (6 live) #1b8 GZIP
Aug 31, 2023 16:44:31.232 [139645719804728] DEBUG - [Req#1b8] [Now] Adding 1 sessions.
Aug 31, 2023 16:44:31.234 [139645811747640] DEBUG - Completed: [192.168.1.3:51234] 200 GET /status/sessions (6 live) #1b8 GZIP 2ms 2921 bytes (pipelined: 50)
Aug 31, 2023 16:44:31.248 [139645769710392] DEBUG - Request: [192.168.1.3:51234 (Allowed Network (Subnet))] GET /video/:/transcode/universal/session/fssydvb929ngan63cxzmapij/1/header (6 live) #1b9 GZIP
Aug 31, 2023 16:44:31.248 [139645696600888] DEBUG - Request: [192.168.1.3:51272 (Allowed Network (Subnet))] GET /video/:/transcode/universal/session/fssydvb929ngan63cxzmapij/0/header (6 live) #179 GZIP
Aug 31, 2023 16:44:31.576 [139645722352440] DEBUG - [Req#1b6/Transcode/fssydvb929ngan63cxzmapij/084de49b-29cf-4515-9c04-2f1b9689716d] Transcoder: session fssydvb929ngan63cxzmapij indicated fallback to software decoding
Aug 31, 2023 16:44:31.615 [139645816347448] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 3307762 is -11 (signal: Segmentation fault)
Aug 31, 2023 16:44:31.615 [139645715585848] DEBUG - Streaming Resource: Terminating session 0x7f01cdafd938:fexcm0mkpafo613hcider89v which is using transcoder slot. Used slots is now 0
Aug 31, 2023 16:44:31.615 [139645748067128] DEBUG - Killing job.
Aug 31, 2023 16:44:31.615 [139645748067128] DEBUG - Signalling job ID 3307762 with 9
Aug 31, 2023 16:44:31.615 [139645748067128] DEBUG - Job was already killed, not killing again.
Aug 31, 2023 16:44:31.615 [139645748067128] DEBUG - Stopping transcode session fssydvb929ngan63cxzmapij
Aug 31, 2023 16:44:31.615 [139645715585848] DEBUG - Streaming Resource: Terminated session 0x7f01cdafd938:fexcm0mkpafo613hcider89v with reason Conversion failed. The transcoder exited due to an error.
Aug 31, 2023 16:44:31.615 [139645715585848] DEBUG - Cleaning directory for session fssydvb929ngan63cxzmapij (/tmp/Transcode/Sessions/plex-transcode-fssydvb929ngan63cxzmapij-084de49b-29cf-4515-9c04-2f1b9689716d)
Aug 31, 2023 16:44:31.617 [139645748067128] DEBUG - Transcoder: Cleaning old transcode directories.
Aug 31, 2023 16:44:31.617 [139645748067128] DEBUG - Whacked session fssydvb929ngan63cxzmapij, 0 remaining.
Aug 31, 2023 16:44:31.621 [139645694491448] DEBUG - Request: [192.168.1.3:51250 (Allowed Network (Subnet))] GET /status/sessions (5 live) #14d GZIP
Aug 31, 2023 16:44:31.621 [139645694491448] DEBUG - [Req#14d] [Now] Adding 1 sessions.
I will write this up and start testing it.
Confirm please the type of media (H264 or H265 ) ?
Also, looks like an Android / Nvidia Shield player device ?
