although I have my plex transcoder pointed to a RAM disk my SSD usage is extremely high.
I can see the transcoded session in the RAM disk, but why is my SSD usage still so high? it is definitely PLEX, because nothing else is running on that machine that could write to the SSD so much.
I guess plex is performing writes to the SSD before transcoding into RAM.
can anybody help me here?
best wishes
There is still a PhotoTranscoder folder on the SSD which is not touched by the plex transcoder settings (which point to the RAM disk). why is this folder 4GB in size and why is it used daily and written to? can this be moved to the RAMdisk?
This folder holds all the resized/optimized picture thumbnails of all kinds which appear in the various Plex clients in various sizes.
This is not “transient” data, so it cannot really be moved to RAM disk.
Disable the following “Plex Butler” jobs under Settings - Server - Scheduled Tasks
Remove old cache files every week
Refresh local metadata every three days
Refresh metadata periodically
and monitor daily writing rates on this folder for at least a week and compare it with the previous rates.
done. will report back in a week. thanks for helping me out. is there any downside to now NOT refreshing metadata periodicallly/refreshing it every 3 days?
But you can try it your way.
If you want you can Report back how and if it works.
I already followed Ottos advice, but every access creates writes to the SSD cache folder (photo thumbnails) again.
So obviously it is not avoidable. That is the reason I am pointing it to the RAMdisk. I guess Plex is clever enough to remove old photo-cache files when the ramDisk gets full.
Yes, right. And if you disable what Otto said than they stay there and they aren´t created again.
I delete the Folder myself if it gets to big.
I don´t know if Plex will do this or complain with an error.
You can try it anyway.
I disabled ottos tasks and new files were created every access. I did not want to create an infinite number of thumbnails that would make my SSD burst. I wanted to stop them being created completely. but I guess that it isn’t possible.
so now I am building them in RAM and hope they are deleted when they are “old”. I guess they are deleted weekly now. I just hope that 10 GB are enough for that. because my RAMdisk is not larger than that.
