Server Version#: 1.19.1.2701
Just wanted to ask why Israel isn’t even an option in the Plex Live TV ?
Have you a supported tuner?
I tried to use Telly which use m3u playlists
You need a supported Tuner and a EPG from your digital terrestrial television area in the form of XML.
I’m using this Telly from github, because I can get better quality stream from the internet than Anthena.
telly is running, you can add it to Plex. Plex Live requires Plex Pass at the time of writingapp.plex.tv and make sure you’re logged in. Go to Settings → Server → Live TV & DVRTHE_IP_WHERE_TELLY_IS:6077 (or whatever port you’re using - you can change it using the -listen commandline argument, i.e. -listen THE_IP_WHERE_TELLY_IS:12345 )telly currently doesn’t have any idea of EPG data so it starts the channel numbers at 10000 to avoid complications with selecting channels at this stage. EPG APIs will come in the future, but for now you’ll have to manually match up what telly is telling Plex to the actual channel numbers. For UK folk, Sky HD is the best option I’ve found.telly .
