Plex UI Bug on Mobile Web unable to select menu options
Server Version#: 1.31.2.6783-9209b39b4 (PlexPass)
Player Version#: Web
When logged into the Plex Web app on both iOS and Android, it’s not possible to use certain menu options due to the touch controls.
Specifically the part I noticed was in the server agents section, when trying to enable opensubtitles, I can only select the row and cannot touch the checkbox :white_check_mark: or the settings gear :gear: on the end.
This makes certain parts of server administration impossible for mobile only users.
Cause: this is likely a html issue/JavaScript issue
Fix: separate the checkbox and gear from the row drag functionality on mobile.
The configuration of the deprecated metadata agents will be the least of your issues if you use a server version which is so outdated.
:sweat_smile: I am actually on the latest version… I just had a powercut so I couldn’t check when I made the post. I’ll update when it’s back on :pray:
I managed to solve this for myself by attaching a Bluetooth mouse to my android tablet.
But I think it’s worth fixing for others who might not have one.
