It seems like each time I update my Plex Server Docker I have an issue that causes me to have to delete plex and its image and start fresh. Is there something I am doing wrong?
Here are the plex Unraid Logs. If further logs are needed please let me know.
Thank you all for your help!
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 40-plex-first-run: executing…
Attempting to obtain server token from claim token
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
Plex Media Server first run setup complete
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 50-plex-update: executing…
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Starting Plex Media Server.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
Critical: libusb_init failed
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
[fix-attrs.d] done.
failed to load external entity “/config/Library/Application Support/Plex Media Server/Preferences.xml”
[cont-init.d] done.
[services.d] done.
[fix-attrs.d] done.
[cont-init.d] done.
[services.d] done.
Each time I restart the server it Hangs at “Starting Plex Media Server” but does not start the system.
