Server Version#: 1.13.5.5332
But I am running unraid 6.5.0. The past couple of weeks I have notice my Plex media Server Docker stops and the only way is for me to get it working gain is my going to Unraid and starting the Plex docker manually. I have place a tick so that it Autostarts.
On the logs from Unraid I get this
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 40-plex-first-run: executing…
[cont-init.d] 40-plex-first-run: exited 0.
[cont-init.d] 50-plex-update: executing…
[cont-init.d] 50-plex-update: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Starting Plex Media Server.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Can someone advise me what is going on ?
