Plex Upgrade Corrupted DataBase
Long time Plex user performed simple update which failed and was cause to Plex Database corruption.
Running Windows 10 and did uninstall of complete Plex solution. Attempted new install of Plex…keep getting Corrupt Database message.
How do I remove this database or how do I found the db…I can delete it once I know where it is located.
-----mikeD (mike@difulvio.net 954-609-5241
You might wanna try and repair the database first, so not to lose all your watched status etc.
https://support.plex.tv/hc/en-us/articles/201100678-Repair-a-Corrupt-Database
Thank you so much for providing the URL as that is just what I needed to resolve the issue.I do hope to repair the DB but push come to shove knowing its location saves me a ton of effort to find what you have provided.
I do feel bad as I suspect this is in a FAQ I could have found and saved your time…thanks again!
------mikeD
