Hello everyone im having some issues with my plex watch web service.
When i try to open the interface it gives me a 401 unauthorized. So i went through and checked the config file, the username and password is set properly, the ports are what they are supposed to be as well. I have access to my server outside my home network, so plex is working fine. I also checked the the plexwatch.log file and its tracking everything as well. I just cant access the web interface. Any suggestions?
Thanks in advance
Mike.
@notorious0ne
How are you trying to access Plex? By going to the IP Address of the computer?
Try putting this in your browser:
192.168.1.152:32400/web/index.html
But change the IP address in the example above with the IP Address of your Plex server. You have to have the “:32400/web/index.html” in there or you aren’t going to get anywhere.
Also, if you’ve changed the listening port of your Plex setup, change the 32400 to whatever you changed it to.
So i ended up fully upgrading my server, and reinstalled everything and having different issues now. “php5-sqlite is not installed. Please install this requirement and restart your webserver before continuing.”
