Server Version#: 1.43.3.10861
Player Version#: Web
Tried to log onto my Plex Server through the web this AM and it’s returning an untrusted cert warning, then some XML, not a web page. The server is up and working otherwise, and it’s processing new media and serving content normally. App clients having no visible issues.
It’s been several weeks since I logged into Plex Web on the server, so not exactly sure when this issue arose.
No idea how to start looking into this. Thoughts ??
The “Y”-generation of certs require a new-ish root certificate to be trusted on your web browser/OS.
Some manufacturers still don’t have this root certificate integrated. Apple for instance, or Sony (on Playstation).
I have triggered the recreation of a new certificate for your server, which is based on the previous root certificate. Try stopping and restarting your server, if it doesn’t pick up the new cert right away.
It should redirect, but even when I explicitly add the /web at the end. Also, restarted this AM and still getting a Y-series cert, albeit a different one than yesterday.
Also seeing only the below in the Trusted Root CA store (W11),
The new cert issued this AM (presumably on forced reboot) has a different signing chain. So, that confirms the what, but not the why.
In theory I could trust these manually and mitigate the symptom, but curious why M$ has not updated them, and why more users are not experiencing the same issue.
That is because the certificate is issued for like: *.<MACHINE_IDENTIFIER>.plex.direct so it will fail if using https://<IP>:32400/web with a warning that it is invalid
You can in the browser select to ignore and continue and it should work
Regarding a redirect from https://<IP>:32400 to https://<IP>:32400/web then that only works if you do not have set the IP address to be allowed without AUTH
So this is strange. I pushed thru the cert error, and also used the /web in the URL, and now it’s coming up with this. No option to sign in or anything:
I’m assuming I have a cached sign-in on this browser session, but have never been prompted to confirm home screen defaults on sign in. The behavior is very different than the past “normal”. Trying to determine why these behaviors started recently (past couple weeks).
Previously I would use “https://local_ip:port”, bypass the cert name mismatch error, and get right in. Now the redirect to “/web” seems required, and the “Customize your media” page is displaying.
This allows a client to bypass authentication and connect to the server directly. When you access in a browser, it gives that prompt first since you’re a “new” user. It allows full access to server settings and content, no profiles. It’s used as a workaround when internet goes down, but it also has impacts like this.
