Plex Won't start on boot Ubuntu 18
Server Version#:4.8.4
Installed Plex on a fresh install of Ubuntu. Everything is working fine, but when I try to enter the terminal command to make Plex boot on startup, I get the following:
carl@Carl-MedServ:/$ sudo systemctl enable plexmediaserver [sudo] password for carl: Failed to enable unit: Unit file plexmediaserver.service does not exist. carl@Carl-MedServ:/$
What am I missing?
DId you install from the Ubuntu store? If so, you need to tell Snap to start it.
systemctl is only valid for regular DEB files.
I did install it from the store. How do I tell snap to start it on boot?
Nevermind. I guess I should have tested it before assuming I had a problem. Snap appears to have it constantly running silently. No need for anything.
