Server Version#: 1.21.3.421
Player Version#: 812422902
Live TV will work for about an hour without issue, then the TV will start buffering ( on screen will show a rewind 10 seconds icon ) then replay the last 10 seconds and keep repeating until I exit the program , delete plex app cache and I’m good for another hour. here is a “small” portion of the log file…
Feb 16, 2021 10:02:12.206 [0x7f3e2ffff700] ERROR - XML: Entity: line 1:\00
Feb 16, 2021 10:02:12.206 [0x7f3e2ffff700] ERROR - XML: parser\00
Feb 16, 2021 10:02:12.206 [0x7f3e2ffff700] ERROR - XML: error :\00
Feb 16, 2021 10:02:12.206 [0x7f3e2ffff700] ERROR - XML: Start tag expected, ‘<’ not found\00
Feb 16, 2021 10:02:12.206 [0x7f3e2ffff700] ERROR - XML: status=ok\00
Feb 16, 2021 10:02:12.206 [0x7f3e2ffff700] ERROR - XML: ^\00
Feb 16, 2021 10:02:12.206 [0x7f3e2ffff700] ERROR - Error parsing content.
Feb 16, 2021 10:02:12.206 [0x7f3e2ffff700] ERROR - Error parsing XML: Error parsing file.
Feb 16, 2021 10:02:12.206 [0x7f3e2ffff700] ERROR - SSDP: Error parsing device schema for http://192.168.1.104:9080
P.S. this log has 75000 lines of that…
When the buffering start exactly matches the times in the log file
Any ideas ??
Bob
