Multiple Parsing errors in Console
Server Version#: 1.25.3.5409
Player Version#: 4.69.1
When looking at the console view I get these errors with regards to parsing XML, missing “<”, and a bunch of other tags for XML. Not sure what that is causing, but it shouldn’t be good right? Attached is my log.
Plex Media Server Logs_2022-01-14_17-10-59.zip (5.0 MB)
Those are usually activities related to network discovery. Plex will talk to systems in your network; some of those devices are using a standardized mechanism to communicate their capabilities/purpose/scope – this information is supposed to be transferred as an XML file. If the information isn’t provided as such, Plex will report this in its logs.
It’s not necessarily a deal breaker. Most of the time you should be fine to proceed without noticing any impact.
Thank you very much, Tom80H. Most appreciated. Is there anything I can or should do to maybe correct this?
Unless you’ve been building your own network equipment and coded how they respond to that kind of requests, I don’t think there’s anything you can do about it.
LOL. Uh, yeah, I’m not that sophisticated. Thanks you so much. You have a Happy New Year!!! Thank you for your support!!
