[Plexamp] 24 Bit WAV Files no direct Play
Hi there
All my 24 Bit WAV Files will be transcoded when i Play it on my Android with Plexamp.
Here some Infos about the File.
Medien
  • Dauer 2:26
  • Bitrate 2304 kbps
  • Container WAV
  • Audio Profile pcm_s24le
Teil
  • Dauer 2:26
  • File 01-01-Droeloe-OATH-SMR.wav
  • Size 40.33 MB
  • Container WAV
  • Codec PCM
  • Kanäle 2
  • Bitrate 2304 kbps
  • Album Gain -12.98
  • Album Peak 1.000000
  • Album Range 12.743377
  • Bit Depth 24
  • Gain -12.98
  • Loudness -9.86
  • Lra 16.20
  • Peak 1.000000
  • Profil pcm_s24le
  • Sampling Rate 48000 Hz
  • Display Title Unbekannt (PCM Stereo)
I have the newest Plex Server Version ( 1.19.1.2645)
Normal Flac Files play normal without transcoding.
In the Plexamp i have in the Quality Settings everything on Maximum.
Thanks for the Help.
Convert them to flac.
