Plexamp 3.9.1 grey screen on macOS
I’m currently running macOS Big Sur 11.6.1 and upon downloading the latest 3.9.1 plexamp I am met with just a grey screen. I ran into this reddit post about setting your NODE_ENV to production, tried this but didn’t seem to help. I am getting what looks like a typescript error in the logs:
Feb 08, 2022 14:15:18.844 [Javascript] WARNING - DEVICE: No provider for source e5d74fb587eeb2d4619aa4c5ff22bb9c1cdcfb05
Feb 08, 2022 14:15:18.845 [Javascript] WARNING - DEVICE: No provider for source e5d74fb587eeb2d4619aa4c5ff22bb9c1cdcfb05
Feb 08, 2022 14:15:18.845 [Javascript] WARNING - IMAGE: Error extracting palette from e5d74fb587eeb2d4619aa4c5ff22bb9c1cdcfb05 /library/metadata/8310/thumb/1634810937 TypeError: Cannot read property 'getImageTranscoderEndpoint' of null
    at x (/Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:1741419)
    at /Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:1742936
    at c (/Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:4207492)
    at Generator._invoke (/Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:4207280)
    at Generator.next (/Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:4207917)
    at n (/Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:4207978)
    at /Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:4208344
    at new Promise (<anonymous>)
    at i (/Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:4208323)
Feb 08, 2022 14:15:18.845 [Javascript] WARNING - Error loading loudness data for track Interpol / The Heinrich Maneuver
Feb 08, 2022 14:15:18.846 [Javascript] WARNING - DEVICE: No provider for source e5d74fb587eeb2d4619aa4c5ff22bb9c1cdcfb05
Feb 08, 2022 14:15:18.846 [Javascript] INFO - Player: Sending state changed [A] Interpol - The Heinrich Maneuver (0/0) in state paused with artwork false.
Feb 08, 2022 14:15:18.846 [Javascript] INFO - PLAYER: Computed soundprint data for track 'Interpol / The Heinrich Maneuver' in 5ms.
Feb 08, 2022 14:15:18.846 [Javascript] INFO - Player: Sending state changed [B] Interpol - The Heinrich Maneuver (0/0) in state paused with artwork false.
Feb 08, 2022 14:15:18.846 [Javascript] INFO - Player: Restoring player route of local with network state 2.
Feb 08, 2022 14:15:18.847 [Javascript] INFO - PLAYER: Setting new palette and loudness data for Interpol / The Heinrich Maneuver
Feb 08, 2022 14:15:18.850 [Javascript] INFO - Audio: Not processing state update of stopped for track .
Feb 08, 2022 14:15:18.851 [Javascript] INFO - App: Stores initialized in 22ms.
Feb 08, 2022 14:15:18.851 [Javascript] INFO - Shortcuts: Initializing!
Feb 08, 2022 14:15:18.851 [Javascript] INFO - App: Stores all initialized.
Feb 08, 2022 14:15:18.852 [Javascript] INFO - App: Boot completed in 150ms.
Feb 08, 2022 14:15:18.873 [Javascript] INFO - Player: Play queue changed from undefined to 358.
Feb 08, 2022 14:15:18.873 [Javascript] WARNING - DEVICE: No provider for source e5d74fb587eeb2d4619aa4c5ff22bb9c1cdcfb05
Feb 08, 2022 14:15:18.875 [Javascript] INFO - Player: Sending state changed [A] Interpol - The Heinrich Maneuver (99624/208457) in state paused with artwork false.
Feb 08, 2022 14:15:18.875 [Javascript] INFO - Player: Sending state changed [B] Interpol - The Heinrich Maneuver (99624/208457) in state paused with artwork false.
Feb 08, 2022 14:15:18.943 [Javascript] INFO - App: Unmounting.
Feb 08, 2022 14:15:18.945 [Javascript] ERROR - TypeError: r.dispatch is not a function
    at Object.navigate (/Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:283310)
    at t.setTopLevelNavigator (/Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:1763025)
    at Tl (/Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:3862375)
    at t.unstable_runWithPriority (/Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:4235696)
    at Va (/Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:3804337)
    at Ml (/Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:3858966)
    at pl (/Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:3855077)
    at /Applications/Plexamp.app/Contents/Resources/app.asar/index.js:2:3804560
Feb 08, 2022 14:15:18.968 [Javascript] INFO - LRUCache: Loudness cache fsck completed in 131 ms, removed 0 files, 0 keys.
Feb 08, 2022 14:15:18.968 [Javascript] INFO - LRUCache: Images cache fsck completed in 131 ms, removed 0 files, 0 keys.
Feb 08, 2022 14:15:19.822 [0x0e08d000] DEBUG - PQCache: Ignoring refresh as a newer one came in.
Feb 08, 2022 14:15:21.844 [Javascript] INFO - AutoPlay: Ends with album: false
Feb 08, 2022 14:15:21.844 [Javascript] WARNING - DEVICE: No provider for source e5d74fb587eeb2d4619aa4c5ff22bb9c1cdcfb05
Feb 08, 2022 14:15:21.845 [Javascript] INFO - DJ: Asked to find more artists, have 0 currently (provider: null).
Feb 08, 2022 14:15:21.845 [Javascript] WARNING - DEVICE: No provider for source e5d74fb587eeb2d4619aa4c5ff22bb9c1cdcfb05
Feb 08, 2022 14:15:21.845 [Javascript] INFO - DJ: Found 0 popular and highly rated tracks for Interpol.
Feb 08, 2022 14:15:21.846 [Javascript] INFO - DJ: Artist queue now has 0 artists (provider: null).
Feb 08, 2022 14:15:21.846 [Javascript] INFO - DJ: Getting recommended tracks for:
Feb 08, 2022 14:15:21.846 [Javascript] INFO - DJ: Found 0 recommendations to add (provider: null).
I tried searching but was mostly met with similar issues on Linux and haven’t really seemed to be promising to resolve the issue. Any other ideas to try? Thanks!
EDIT: Something worth mentioning is I’ve had plexamp installed before and using a source for a server that I recently removed the music library from and re-added.
I found a fix for my system, it was to remove all the previous configuration from when I had plexamp installed before and connected to my old library. A simple
rm -rf ~/Library/Application Support/Plexamp and relaunching plexamp resolved this for me.
