Since the 4.6.0 update, on W10 21H2, the Shuffle and Repeat buttons are no longer visible on the playback window.
The buttons were visible in the 4.5.X updates.
Thanks,
Josh
[mod-edit: tagged the images so they show up in the post]
Thanks,
Josh
Try slightly widening the window. The app is using a responsive design and will drop some UI controls if there’s not enough space to draw them.
Hi Tom,
Making the window just slightly wider does bring the buttons back, but unfortunately I have the window in a specific position/size, and the buttons were there previously, as recently as the previous version.
If the change is intentional, due to the Guest DJ button, could there be a setting to choose which buttons are visible, so you could choose to hide the buttons you don’t want?
Thanks,
Josh
