Hi, I just discovered a bug in plexamp front-end. Here is the bugreport.
System details:
Plexamp version: 3.4.7
Operating System: Mac OS Big Sur (11.4)
PMS version: 1.23.2 (on Linux Mint 20.1)
Steps to reproduce:
Resize the plexamp window to a very thight window
Play some music
Results:
Shuffle, repeat and “back to menu” buttons are covering each other rendering each other pretty unpredictable.
Expected:
Shuffle, repeat and “back to menu” buttons are not covering each other.
elan
June 11, 2021, 7:26pm
2
Not a lot of room left there, I think for starters we’d just move to hiding shuffle/repeat below a certain width
Pretty expected however I would opt vice versa and hide casting and playlist buttons. Playlist can also be reached by using the scroll wheel so that would leave only 1 function unavailable instead of 2.
Thanks for the fix. I just have 1 thing to say about it. The alignment of both buttons does not seem to be correct.
(Go ahead, I deserved the facepunch)
elan
July 3, 2021, 7:16pm
5
you’re right, it is off by a bit
