Last couple of days my Pixel 5 battery has been draining and both times it’s plexamp as below, would logs help determine what’s going on?
Edit: no background usage reported at all!
Same here. Checking the forum if there is a fix for the massive battery drain.
Logs would be useful for this, thanks!
I have a pixel 6a, that might already help, as I can see the original poster has a pixel 5. Both use the tensor processor, as far as I know.
I’ll check if I can get somehow reasonably to the log data on the phone.
I’m also on a Pixel 6a and don’t experience the severe battery drain reported, so logs will be important to find out what may be the cause ![]()
On a Pixel 7 Pro and experiencing high battery drain. I have to force close the app after using to avoid it.
Attaching logs here.
Plexamp.log (32.5 KB)
Plexamp.1.log (1.3 MB)
Pixel 4a here. Same issue. Can’t figure out how to get logs to post here.
Plexamp.log (52.7 KB)
Plexamp.1.log (38.5 KB)
Plexamp.2.log (38.2 KB)
Plexamp.3.log (61.4 KB)
Plexamp.4.log (120.1 KB)
Plexamp.5.log (47.2 KB)
Settings → Advanced → Debugging → Share Logs
Thanks. I couldn’t figure out how to save the zip file and had to save it to my Google drive then download it and unzip.
