Plexamp and Volumio
Hi, I’ve been using Plaxamp right from the start and have been a big fan since then. For a few months I’ve started using Volumio.
Is there any way to connect Plexamp and Volumio with each other?
Thanks in advance for any help…
I am on a similar solution, however I am trying to build a touchscreen with a RPI to have direct controls instead of using a phone or browser to control playback.
Played around with HiFi Berry and Volumio… while it works pointing to the music share from plex via SMB, it just doesn’t feel right. It uses it’s own metadata, which doesn’t match what i’ve curated in Plex.
The closest solution to what I would like is to use Fyde OS (chromeOS variant) on an RPI 4 and configuring the playstore to install Plexamp. Just need to figure out how to get the official RPI touchscreen to work with Fyde and I’d be a happy camper.
@enduser Thanks for your input, I won’t be using a touchscreen but I’m certainly going to try your suggestion.
