Plexamp, Apple keyboard media controls not working
Server Version#4.137.1
Player Version#:4.11.1
Odd issue with Plexamp on Mac OS 14.16.1
The media keys on the apple keyboard (Play/Pause, Rewind and Forward) aren’t working just for Plexamp.
They work fine for the browsers playing media and Apple Music.
I restarted and made sure the system and app is updated.
I also deleted and re-installed Plexamp.
I think there are saved preference files that are not in /Library/Prefrances
The reason I think this is that it loaded Plexamp back to the same point after the re-install.
I tried another apple keyboard and it was still not working…
Any ideas to try would be great, at least how to full remove the app and and associated files would be great.
