Plexamp Beta 42
Hello, I don’t understand—I’ve lost the desktop view for Plexamp; has it been removed?
Windows: Ctrl+Alt+1
macOS: Cmd+Alt+1
Is there a way to see which beta build I am on? “About” always says only v4.50.20 even after an update.
Anyway I restarted Plexamp and let it update itself until it ran out of updates, so presumably I am on the latest beta build, and I cannot reproduce the issue on Win 11.
If you’re on .20, you’re on the stable branch.
https://plexamp.plex.tv/downloads.html#beta
Settings → About will always show your version.
