Plexamp EQ settings not saving
Server Version#:
1.82.2.4024-64f483f6
i recently noticed that EQ settings are no longer saving on exit in the Flatpak version of Plexamp. They revert back to the settings I saved a few months ago.
I figured out the issue. I was trying to use a preset and not touching the settings. If I activate the preset, move a slider, then close the preset will save. Saving requires direct interaction with the EQ.
Thanks for the details! Confirmed over here, will look into it.
