Can I add multiple sets of EQ parameter storage to Plexamp?
I have many sets of speakers and headphones, each of which hopes to store the best sound EQ.
No and Yes and Sort of.
No for Speakers. At the moment one custom EQ for speakers, but if you move off of that custom EQ you will lose your settings. Plexamp doesn’t save unique user created EQ presets, and it does not match that EQ up with your output speakers. You will have to manually make the changes each time.
Yes for headphones, sort of.
Yes for headphones in that headphones have presets that Plexamp pulls in.
If you go into the EQ, => Search Presets => Choose your headphone, Plexamp will then save it as a recently used list. So next time you can go into EQ and just tap from the list, and it will pull it up. But it will overwrite whatever is already there. And you have to do that each time.
Screen Shot 2023-05-02 at 1.31.04 PM
