Plexamp feature request: Keep screen on while charging
Just like the topic says, it would be great if there was an option to keep the screen on while the phone (Android, in my case) is charging. My specific use scenario is in the car. Obviously there’s the option to keep the screen on all the time, but that’s a little clunky.
I don’t suppose the “keep screen on while in the player” setting helps? Usually I don’t put the phone down with the player on unless I want it to keep the screen on.
Hey, thanks for the reply. Yes, that works, and is what I was referring to. The only reason I would prefer the “while charging” option is to avoid putting it in my pocket with the screen on. Simple matter to avoid, just turn the screen off. But I’m a direct descendant of apes, and would absolutely screw that up on occasion.
OMG we’re related!
So perhaps the setting would change to:
Keep screen on:
  • When on player screen
  • When charging
Something like that?
Exactly, cousin.
