Here’s the logs: (I immediately played fine from the web browser fine after that)
Feb 20, 2023 09:20:48.135 [0x0d7fa140] INFO - Cache: Buffering complete as offset is now greater than 588800 (589824) and read completed: 0.
Feb 20, 2023 09:20:48.135 [0xfffff140] WARNING - Cache: READ underflowed at 589824 bytes, will go into buffering state.
Feb 20, 2023 09:20:48.135 [0xfffff140] INFO - Cache: Buffering until offset reaches 1767424 (read buffer offset: 589824, size: 1177600).
Feb 20, 2023 09:20:48.135 [0x0dffb140] INFO - BASS: Stream 347452 (channel 0x00000000) changed buffering state to 1.
Feb 20, 2023 09:20:48.180 [0x0cff9140] INFO - PQCache: Requesting play queue with 1 items ahead.
Feb 20, 2023 09:20:48.209 [0x0cff9140] INFO - Cache: HTTP response code was 200.
Feb 20, 2023 09:20:48.209 [0x0cff9140] INFO - Cache: HTTP response total size was 3149.
Feb 20, 2023 09:20:48.212 [0x0cff9140] INFO - PQCache: Parsed play queue from JSON (13949 bytes).
Feb 20, 2023 09:20:48.212 [0x0cff9140] INFO - PQCache: Parsed 5 items (2 currently active).
Feb 20, 2023 09:20:48.657 [0x0e7fc140] INFO - Cache: Asked to seek to offset 48372642 with read buffer offset at 921600.
Feb 20, 2023 09:20:48.657 [0x0e7fc140] INFO - Cache: That sucks, total cache fail on seek. Such is life.
Feb 20, 2023 09:20:48.757 [0x0d7fa140] INFO - Cache: Ending network read thread.
Feb 20, 2023 09:20:48.761 [0x0e7fc140] INFO - Cache: Buffering until offset reaches 48961442 (read buffer offset: 48372642, size: 588800).
Feb 20, 2023 09:20:48.761 [0x0d7fa140] INFO - Cache: Kicking off buffering thread at offset 48372642, disk cache has 933888 / 54382970.
Feb 20, 2023 09:20:48.761 [0x0d7fa140] INFO - Cache: We’ve been asked to buffer a disjoint region, we’ll just stream from network.
Feb 20, 2023 09:20:48.801 [0x0d7fa140] INFO - Cache: HTTP response code was 206.
Feb 20, 2023 09:20:48.801 [0x0d7fa140] INFO - Cache: HTTP response total size was 6010328.
Feb 20, 2023 09:20:48.903 [0x0e7fc140] INFO - Cache: Asked to seek to offset 48365004 with read buffer offset at 48409506.
Feb 20, 2023 09:20:48.903 [0x0e7fc140] INFO - Cache: That sucks, total cache fail on seek. Such is life.
Feb 20, 2023 09:20:48.904 [0x0d7fa140] INFO - Cache: Ending network read thread.
Feb 20, 2023 09:20:48.907 [0x0e7fc140] INFO - Cache: Buffering until offset reaches 48953804 (read buffer offset: 48365004, size: 588800).
Feb 20, 2023 09:20:48.907 [0x0d7fa140] INFO - Cache: Kicking off buffering thread at offset 48365004, disk cache has 933888 / 54382970.
Feb 20, 2023 09:20:48.907 [0x0d7fa140] INFO - Cache: We’ve been asked to buffer a disjoint region, we’ll just stream from network.
Feb 20, 2023 09:20:48.933 [0x0d7fa140] INFO - Cache: HTTP response code was 206.
Feb 20, 2023 09:20:48.934 [0x0d7fa140] INFO - Cache: HTTP response total size was 6017966.
Feb 20, 2023 09:20:48.935 [0x0e7fc140] DEBUG - BASS: Initial mixer offset 403.0 sec.
Feb 20, 2023 09:20:48.935 [0x0e7fc140] DEBUG - BASS: Setting stream gain for 347452 to -4.4 dB.
Feb 20, 2023 09:20:48.935 [0x0e7fc140] INFO - BASS: Opened stream 347452 in 1760 ms (paused: 1) with gain -4.4 dB, max 0 Kbps (picked flac, 925 Kbps, actual 940 Kbps/sec).
Feb 20, 2023 09:20:48.935 [0x0e7fc140] INFO - BASS: Created a gapless source stream for 347452 (channel: 0x80000013) with sample rate of 44100 and 2 channels (paused: 1)
Feb 20, 2023 09:20:48.935 [0x0e7fc140] INFO - BASS: Reading first bytes to ensure stream 347452 is warmed up.
Feb 20, 2023 09:20:49.036 [0x0e7fc140] DEBUG - BASS: Enabling limiter.
Feb 20, 2023 09:20:49.859 [0x0d7fa140] INFO - Cache: Buffering complete as offset is now greater than 48953804 (48954828) and read completed: 0.
Feb 20, 2023 09:20:49.859 [0x0dffb140] INFO - BASS: Stream 347452 (channel 0x80000013) changed buffering state to 0.
Feb 20, 2023 09:20:49.859 [0x0dffb140] INFO - BASS: Not touching channel state because we’re paused.
Feb 20, 2023 09:20:49.860 [Javascript] INFO - Audio: State changed from buffering to paused.
Feb 20, 2023 09:20:49.860 [Javascript] INFO - PlayQueue: Saving state {“source”:“489df7b9a696f17132f4b1e3372adae6e17541d4”,“state”:“paused”,“time”:403007,“rate”:1,“volume”:100,“playQueueID”:“6754”,“playQueueVersion”:2,“playQueueItemID”:“347452”}
Feb 20, 2023 09:20:49.871 [Javascript] INFO - Player: State transition buffering → paused for source local ID 347452.
Feb 20, 2023 09:20:49.881 [Javascript] INFO - Player: Sending state changed [A] Guns N’ Roses - Civil War (403007/462466) in state paused with artwork false.
Feb 20, 2023 09:20:51.745 [Javascript] INFO - HttpServer: [10.99.71.230] GET /player/playback/play commandID=15&type=music
Feb 20, 2023 09:20:51.747 [0x89bbc140] INFO - BASS: Resume.
Feb 20, 2023 09:20:51.747 [0x89bbc140] DEBUG - BASS: Ensuring we’re not idle.
Feb 20, 2023 09:20:51.747 [0x89bbc140] DEBUG - BASS: Resetting device (soft: 0, initialized: 1).
Feb 20, 2023 09:20:51.747 [0x89bbc140] DEBUG - BASS: Moving from decode only to real playback.
Feb 20, 2023 09:20:51.747 [0x89bbc140] DEBUG - BASS: Suspending device (sample rate: 44100, num channels: 2, soft: 0, decode only: 0, force: 1)
Feb 20, 2023 09:20:51.747 [0x89bbc140] DEBUG - BASS: Suspending 2 currently active channels.
Feb 20, 2023 09:20:51.747 [0x89bbc140] DEBUG - BASS: Tearing down audio stack.
Feb 20, 2023 09:20:51.749 [0x89bbc140] DEBUG - BASS: Resuming device (sample rate: 44100, num channels: 2, soft: 0, decode only: 0, force: 1)
Feb 20, 2023 09:20:51.749 [0x89bbc140] DEBUG - Mixer: Initializing audio pipeline with sample rate: 44100 channels:2 soft: 0.
Feb 20, 2023 09:20:51.752 [Javascript] INFO - Player: Sending state changed [A] Guns N’ Roses - Civil War (403007/462466) in state playing with artwork false.
Feb 20, 2023 09:20:51.787 [0x89bbc140] ERROR - BASS: Error initializing device -1 with sample rate 44100 and flags 00000000 (3).
Feb 20, 2023 09:20:51.787 [0x89bbc140] DEBUG - BASS: Creating a mixer with sample rate 44100 and 2 channels (decode: 0).
Feb 20, 2023 09:20:51.787 [0x89bbc140] ERROR - BASS: Error [m_mixer = BASS_Mixer_StreamCreate((DWORD)sampleRate, (DWORD)channels, flags)] - 8
Feb 20, 2023 09:20:51.787 [0x89bbc140] DEBUG - BASS: Adding back 2 streams after recreating mixer — 0x8000000d (flags: 00020000) 0x80000013 (flags: 00820000)
Feb 20, 2023 09:20:51.787 [0x89bbc140] DEBUG - BASS: We have 0 dying streams which we’re going to kill immediately.
Feb 20, 2023 09:20:51.787 [0x89bbc140] ERROR - BASS: Failed to start mixer, error 5.
Feb 20, 2023 09:20:51.787 [0x89bbc140] INFO - BASS: Resuming audio output (started: 0)
Feb 20, 2023 09:20:51.787 [0x89bbc140] ERROR - BASS: Error resuming, restarting entire system.
Feb 20, 2023 09:20:51.787 [0x89bbc140] DEBUG - BASS: Resetting device (soft: 0, initialized: 1).
Feb 20, 2023 09:20:51.787 [0x89bbc140] WARNING - BASS: Couldn’t start, so we’re not doing a soft configure.
Feb 20, 2023 09:20:51.787 [0x89bbc140] DEBUG - BASS: Suspending device (sample rate: 44100, num channels: 2, soft: 0, decode only: 0, force: 0)
Feb 20, 2023 09:20:51.787 [0x89bbc140] DEBUG - BASS: Changing mixer from 0/0 to 44100/2.
Feb 20, 2023 09:20:51.787 [0x89bbc140] DEBUG - BASS: Suspending -1 currently active channels.
Feb 20, 2023 09:20:51.787 [0x89bbc140] ERROR - BASS: Error fetching mixer channels - 5
Feb 20, 2023 09:20:51.787 [0x89bbc140] DEBUG - BASS: Tearing down audio stack.
Feb 20, 2023 09:20:51.787 [0x89bbc140] ERROR - BASS: Error [BASS_Stop()] - 8
Feb 20, 2023 09:20:51.787 [0x89bbc140] ERROR - BASS: Error [BASS_Free()] - 8
Feb 20, 2023 09:20:51.787 [0x89bbc140] DEBUG - BASS: Resuming device (sample rate: 44100, num channels: 2, soft: 0, decode only: 0, force: 0)
Feb 20, 2023 09:20:51.787 [0x89bbc140] DEBUG - Mixer: Initializing audio pipeline with sample rate: 44100 channels:2 soft: 0.
Feb 20, 2023 09:20:51.788 [0x89bbc140] ERROR - BASS: Error initializing device -1 with sample rate 44100 and flags 00000000 (3).
Feb 20, 2023 09:20:51.788 [0x89bbc140] DEBUG - BASS: Creating a mixer with sample rate 44100 and 2 channels (decode: 0).
Feb 20, 2023 09:20:51.788 [0x89bbc140] ERROR - BASS: Error [m_mixer = BASS_Mixer_StreamCreate((DWORD)sampleRate, (DWORD)channels, flags)] - 8
Feb 20, 2023 09:20:51.788 [0x89bbc140] DEBUG - BASS: We have 0 dying streams which we’re going to kill immediately.
Feb 20, 2023 09:20:51.788 [0x89bbc140] ERROR - BASS: Failed to start mixer, error 5.
Feb 20, 2023 09:20:51.788 [0x89bbc140] ERROR - BASS: Error resuming, restarting entire system.
Feb 20, 2023 09:20:51.788 [0x89bbc140] DEBUG - BASS: Resetting device (soft: 0, initialized: 1).
Feb 20, 2023 09:20:51.788 [0x89bbc140] WARNING - BASS: Couldn’t start, so we’re not doing a soft configure.
Feb 20, 2023 09:20:51.788 [0x89bbc140] DEBUG - BASS: Suspending device (sample rate: 44100, num channels: 2, soft: 0, decode only: 0, force: 0)
Feb 20, 2023 09:20:51.788 [0x89bbc140] DEBUG - BASS: Changing mixer from 0/0 to 44100/2.
Feb 20, 2023 09:20:51.788 [0x89bbc140] DEBUG - BASS: Suspending -1 currently active channels.
Feb 20, 2023 09:20:51.788 [0x89bbc140] ERROR - BASS: Error fetching mixer channels - 5
Feb 20, 2023 09:20:51.788 [0x89bbc140] DEBUG - BASS: Tearing down audio stack.
Feb 20, 2023 09:20:51.788 [0x89bbc140] ERROR - BASS: Error [BASS_Stop()] - 8
Feb 20, 2023 09:20:51.788 [0x89bbc140] ERROR - BASS: Error [BASS_Free()] - 8
Feb 20, 2023 09:20:51.788 [0x89bbc140] DEBUG - BASS: Resuming device (sample rate: 44100, num channels: 2, soft: 0, decode only: 0, force: 0)
Feb 20, 2023 09:20:51.788 [0x89bbc140] DEBUG - Mixer: Initializing audio pipeline with sample rate: 44100 channels:2 soft: 0.
Feb 20, 2023 09:20:51.788 [0x89bbc140] DEBUG - BASS: Taking mixer pause flag off channel.
Feb 20, 2023 09:20:51.788 [0x89bbc140] DEBUG - BASS: Resumed in 41 ms.
Feb 20, 2023 09:20:51.791 [Javascript] INFO - Player: State transition playing → paused for source local ID 347452.
Feb 20, 2023 09:20:51.795 [Javascript] INFO - Player: Sending state changed [A] Guns N’ Roses - Civil War (403007/462466) in state paused with artwork false.
Feb 20, 2023 09:20:51.817 [Javascript] INFO - HttpServer: [10.99.71.230] GET /player/playback/setParameters volume=100&commandID=16&type=music
Feb 20, 2023 09:20:51.818 [Javascript] INFO - PlayQueue: Saving state {“source”:“489df7b9a696f17132f4b1e3372adae6e17541d4”,“state”:“paused”,“time”:403007,“rate”:1,“volume”:100,“playQueueID”:“6754”,“playQueueVersion”:2,“playQueueItemID”:“347452”}
