Plexamp IOS 3.1.1 Smart Playlist support
Only static playlists are showing in the app, no smart playlists. Are they supported?
Yes, they definitely are.
Where are you looking for them?
Do you have selected the Plex library, where those playlists are created? (Plexamp settings - Source)
I am definitely in the right library since I see all other static playlists. I use the new Library tab, then Playlists. I even created two new ones on my desktop using web app as a test… one static, one Smart. Static is available in PlexAmp but Smart is not.
Am I missing something? Are the Smart playlists somewhere else in PlexAmp?
I can see all my playlists in there.
Are you using a managed user account in Plexamp?
Nope. Same owner acct that I use on all my devices/logins. In fact, I switch over to the Plex IOS app and I can see all the playlists, static and smart.
