Plexamp: minimize to tray on Windows 7 and pause/play problem
Hi!
Is it possible to minimize Plexamp to tray on Windows 7 ?
I’m having another problem. When I pause the playback and then click on resume, the icon changes to play but the song doesn’t play…
Thanks!
The resuming from pause issue has been noted by others as well, we’ll look into it. You can set Nihilist mode in the Size menu, which has a similar effect to minimizing to tray :smiley:
Oh. Thanks for quick replay!
Any other fixes at the moment for minimize to tray? Seems like no right? :smile:
